Home Audio SpeakersDiscuss What's more practical 16 or 18 gauge wire? in the Manufactured Speakers | Subwoofers forum; What's more practical 16 or 18 gauge wire? I think the link above is a good reference point.... |
Views: 5554 - Replies: 34
| | #12 | ||||
| Re: What's more practical 16 or 18 gauge wire? I disagree with the above chart because it does not have any wattage ratings or the type of speaker listed. A 4ohm load over a 22awg wire 6' in length powering speakers that need 150 watts to reach reference would melt the wire after some time of use or cause other issues ![]() Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #13 | ||||
| Re: What's more practical 16 or 18 gauge wire? I'm no EE so you would have to take that up with the author. I agree if your running a pair of 18" subs in a rock concert you might have a heat problem, normal home use might be a different story. | ||||
| | #14 | |||||
| Re: What's more practical 16 or 18 gauge wire? Hiyas, WHY? Quote:
HSU research sound told me usually it's 16ga for under 25' run, and 14ga,for 25' and over, but I justpicked up my speakers, and he told me to run it all with the 14ga,if the extra price is not much more than the 16ga.. I think I'm going with the Monoprice Enhanced Loud Oxygen-free copper 14 awg. For the 150' linear total footage, it's $10.76 more for the 14ga, (BEST) than the 16ga (better) for a 100',and 50' spool. On the other hand, these small speakers are NOT JBL, Infinity,Mirage, or Definitive, floor-standers, or even bookshelves, they are satellites... they are rated as follows: 80hz-20khz / 90db Sensitivity,1 watt,1 meter / 8ohm /10-125 watt recommended amp power / less than 2 lb speakers. The only thing I found to anchor this speaker wire around door jambs and baseboards are 1/4" cable clips. Also, looking at expensive Vantage point speaker wall Mounts, @ 39.99 a pair, that should add up to a pretty penny. These speakers rec. Omnimount 10. Wall mounts at Monoprice #item# 3012 sell for less than $5.00,but not sure if they tilt from side to side. I need a pivot, so I can move in any direction instead of facing flush out with the wall. Thanks! Last edited by bozobytes; 04-01-09 at 08:24 PM.. | |||||
| | #16 | |||||||
| Re: What's more practical 16 or 18 gauge wire? Someone said this.... Quote:
Who's right? What would happen if i cut to length each speaker run from the AVR to each speaker? This is a 6.1 set up. Two fronts,two rears,one center-rear,one center,and one sub. 12x12 room=thatsa lotsa wire!!!! | |||||||
| | #17 | |||||
| Re: What's more practical 16 or 18 gauge wire? Quote:
brucek | |||||
| | #18 | ||||
| Re: What's more practical 16 or 18 gauge wire? I cant wrap my head around the fact that the graph shows a 22 awg wire at 6 ft long can power a 4 ohm speaker and he make no real mention of how much power (wattage) the speaker requires at a given volume. I tried something last night and I can say for sure that my towers did not sound as good with 18 awg wire (the smallest I had lying around) as they do with my current 12awg wire that I normally use. The volume level was lower and the sound seemed off. It was a simple test and the results for me were very clear. Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #19 | |||||
Take a look at some 22 gauge wire. It typically has a DCR of 16.14 ohms per 1000 feet. If I calculate the total resistance of that 6 foot cable (to the speaker and back) in relation to 4 ohms, there will be a 4.6% power loss in the cable. That's 0.2dB. Most of the problems with respect to audio in long speaker cables is inductive reactance, where very long runs tend to act as a low pass filter. It's easily calculated though. brucek | |||||
| | #20 | ||||||||
But if anything makes a difference with speaker wire, it’s size (gauge). Over the years on both the audio forums and my own personal experience I’ve seen that most people claiming speaker wire makes an audible difference will say so after switching from small-gauge to large-gauge wire. For instance, years ago a good buddy of mine asked if I thought he would hear a difference if he switched out the 20ga. stuff that came with his 80s Yamaha rack system in favor of some 14ga. wire. The speakers were rather cheap, and it was only about a 8-ft. run - and he didn’t strike me as a guy with especially fine-tuned hearing. So I told him “I doubt it.” He did the switch anyway, and to my surprise he came back with “It definitely sounds better.” The reason wire gauge can make an audible difference most likely has to do with its resistance (which is naturally a function of its gauge and length) and how that relates to a particular speaker’s overall impedance. Not its rated impedance; that’s merely a nominal figure. Anyone who has seen an impedance curve graph for a speaker knows that the speaker’s impedance can vary wildly across the frequency spectrum. If a speaker’s impedance drops particularly low at certain frequencies, then it makes sense that resistance added by small-gauge speaker cable could easily affect the way the speaker sounds at those frequencies. And it makes sense, in that situation, that changing from small- to large-gauge speaker wire would make an audible difference (hopefully better). It logically follows that speakers with higher nominal impedance ratings of say, 8-ohms may not respond as dramatically to a change to larger gauge wire as speakers with a 4-ohm rating, which often use 2-ohm drivers (!). It also follows that speakers with a fairly linear impedance curve across the frequency spectrum may not respond the same as speakers whose impedance at places dips to very low values at certain frequencies. This is why you will such get varied responses from people as to whether or not heavy-gauge wire made their speakers sound better. Obviously it heavily depends on the particular speakers involved, the lengths of wire they used, the size of their original wire vs. what they upgraded to, and so forth. At the end of the day, the typical recommendation to use only 12 or 14-gauge is based on “better safe than sorry” more than anything else. I.e. more practical than scientific. Will it make an audible difference over smaller gauge wire? Maybe, maybe not. But who wants to go through the time and expense of buying speaker wire in various lengths and gauges and conducting listening experiments? Just go with the 12-gauge and be done with it, or at least 14-gauge. That said, home theater often brings other issues to the table: Quote:
). But as you’ve noted, it isn’t always practical to use the “best” speaker wire, especially in situations where it can’t be easily hidden. Often compromises have to be made between performance and aesthetics. After all, we do have to live in these rooms, especially if they aren’t dedicated. The advice would be to go with the largest gauge you can live with, visibly-speaking. Hopefully that would be no smaller than 16-gauge, at least for the front speakers. Fortunately with home theater, “all speakers are not created equal.” The front three channels are the most important. The rear channels carry mainly ambient effects and are not the primary focus of your attention As such the rear speakers are much, much less susceptible to compromises in speaker wire choices from an audibility standpoint. Quote:
Practically speaking, if music listening is important to you, you might want to try to keep the cables for the front left and right speakers the same length. That said, it’s unlikely that having one speaker cable say, 5 ft. and one 10 ft. will make an audible difference. But if it does, it would be a bigger chance of being audible with 18-gauge wire than it would be with 12-gauge. And once again, how big of a potential issue it would be may also be dependant on the particular speaker in question. Clear as mud? : This is why people often take a “better safe than sorry” stance and keep the front left and right cables the same length, if at all possible. ) With home theater considerations the “rules” are once again much less clear. The rear speakers are not nearly as critical as the front L/R, and as you noted it’s a bit silly to cut two 50 ft. lengths of cable when one only needs 20 ft. The worst thing that can happen with drastically different rear cable lengths is that one speaker may end up a bit lower in volume than the other, due to the added resistance of the longer wire. And (again) if there is an issue, it will be more pronounced with small gauge wire. Fortunately, the receiver has level adjustment controls to take care of this problem, if indeed it turns out to be one. By the way, you might want to check my in-wall speaker wiring article (see the link in my signature). If you can get your wire around the baseboards to just below the speaker location, it’s pretty easy to get the wire in-wall from there up to the speaker. Maybe this would keep you from having to run exposed wiring up the corners and give you more options on wire size. Regards, Wayne | ||||||||
