Home Audio Speakers
Any thought on this one?
Discuss Any thought on this one? in the Manufactured Speakers and Subwoofers forum; Any thought on this one? I am considering swapping out my existing system for an active monitor system... 5.1 to start with. Does anyone have ...
Views: 233 - Replies: 3
Old 04-16-09, 03:00 PM   #1
Alias: dj_synn
Loc: Woodland Park, CO
User: #36478
Since: Apr 2009
  dj_synn is offline
I am considering swapping out my existing system for an active monitor system... 5.1 to start with. Does anyone have any good reasons (besides power outlets) why this would not be a good idea? Thanks
Old 04-16-09, 04:43 PM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Any thought on this one?
You might want to make the thread title something more specific. People tend to ignore generic threads.
You have asked a very general question as well. The best answer that I can give is that it depends on the system. Mostly, the idea of active systems is a good one, but the execution can vary, just like with passive speakers. The biggest downside that I can think of is cost, perhaps followed by serviceability.
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
Old 04-16-09, 04:49 PM   #3
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Active speakers, (self powered) tend to be designed for larger environments and in my opinion do not sound as good. That said Yamaha makes some nice studio monitors that are self powered so there are options out there I just dont think that for the money you are getting a better speaker system.
The traditional Receiver or pre-pro with speakers gives you alot more choice.
EDIT: I forgot to also mention that running line level signals over long distances (to speaker locations) is far more prone to interference than speaker wire plus the cost of XLR or good RCA cables is much higher than wire.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 04-16-09, 06:06 PM   #4
Alias: dj_synn
User: #36478
Since: Apr 2009
  dj_synn is offline
To answer some of those questions, the monitors in question are not for large scale reproduction and therefore don't have the limitations that "pro" audio has to deal with, such as a lack of sound quality. The monitors in question are from Focal, http://www.focalprofessional.com/en/cms-line/cms-65.php Not too pricey, at roughly $650 ea, and they are quite a bit less cash than the other Focal stuff that would be the alternative. I have some decent stuff now, but it just doesn't cut the mustard compared to the Focal Electra series, which would be the alternative. But part of the reason for the monitors is some pressure from the wife to "keep it simple", by which she means "as small as possible while still sounding good".... does that make any sense at all? lolol
hope i'm not being a pain in the neck
one?, thought
