Home Audio Speakers
New to the "shack" and seeking help
Discuss New to the "shack" and seeking help in the Manufactured Speakers and Subwoofers forum; New to the "shack" and seeking help I am new to the Shack and am in need of some help. I have been in my home 3 ...
Views: 230 - Replies: 14
Old 04-20-09, 03:39 PM   #1
Alias: damon
Loc: hooper,utah
User: #23603
Since: Jul 2008
  damonb70 is offline
I am new to the Shack and am in need of some help. I have been in my home 3 years now and i have a dedicated room that is going to be my theater (17 feet wide x 27 feet deep x 8' ceiling). I have heard things from lots of people. Where does one start? Sub Woofer? Screen size? I'm lost.
Old 04-20-09, 03:42 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: New to the "shack" and seeking help
Hi Damon, Welcome to the Shack.
Your room dimensions are quite good but on the large size so for starters you will need a system with a bit of oomph.
Do you have a budget in mind?
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 04-20-09, 04:12 PM   #3
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
Welcome Damon. I am glad you are starting your quest for the HT experience. If you could ask some specific questions and give us a budget, we can help. Have fun. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 04-20-09, 04:16 PM   #4
Alias: Kai
Kai Winters's Avatar
Loc: Brownville, NY
User: #36079
Since: Apr 2009
  Kai Winters is offline
You should start with a basic budget, then add 10 to 20% for the unexpected, then an idea of what you want the room to provide.
Will it be a bit multi-purpose with a wet bar, etc?
Do you want to use a projector, flat panel, etc?
What sort of furniture do you want to use? Furniture lying around the house now or new? If you are planning and have room for rows of seating you need to think about a riser for the rear seats.
I would start looking at the Home Theater Gallery on this site, and perhaps others, for what others have done to get some ideas to get your imagination going.
This could be a lot of fun for you and us as we watch you progress and help in whatever way we can.
Old 04-20-09, 04:18 PM   #5
Alias: damon
Loc: hooper,utah
User: #23603
Since: Jul 2008
  damonb70 is offline
no budget at the present time, would definitely like to use a pair of svs pb13 ultras. the rest i'm not sure .
Old 04-20-09, 04:21 PM   #6
Shack Moderator
Alias: Dr Doan
User: #2314
Since: Aug 2006
  drdoan is offline
You are right on with the SVS's. You should decide on which medium you want for tv. Projection, flat screen-plasma, lcd, etc. Is the room going to be dark enough for projection? Dennis
L Dennis Doan, DC
IT'S THE NERVE!
www.drdoan.com
Direct TV DVR HD
Old 04-20-09, 04:21 PM   #7
Alias: damon
Loc: hooper,utah
User: #23603
Since: Jul 2008
  damonb70 is offline
i am so lost as far as this whole project is concerned
i have had guys tell me the only way to go is by mounting LCR & subs all on the front wall.
Old 04-20-09, 04:32 PM   #8
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Dont worry about sub placement right now your room is almost the same size as mine and your able to get a decent sized screen and have the mains and subs up front. You should have no issue going with a 106" diagonal screen.
Two rows of seating will give you a 14' from the screen front row and a 18' second row with several feet to spare behind the second row for rear speaker placement.
SVS not only makes great subs but their speaker line is fantstic as well.
Home theater:
Two Channel system:
My Webpage
Old 04-20-09, 04:34 PM   #9
Alias: damon
Loc: hooper,utah
User: #23603
Since: Jul 2008
  damonb70 is offline
I am wanting to do a projector, screen size would be 106"
Old 04-20-09, 04:38 PM   #10
Alias: damon
Loc: hooper,utah
User: #23603
Since: Jul 2008
  damonb70 is offline
i had a home theater guy out here tell me to use speakers in a bad boy series
Old 04-20-09, 04:44 PM   #11
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
I dont know what you mean by the "bad boy series" term, is this a brand of speaker?
Home theater:
Two Channel system:
My Webpage
Old 04-20-09, 09:09 PM   #12
Alias: Dave
Loc: Mechanicsburg, PA
User: #19259
Since: Apr 2008
  dewd is offline
damonb70 wrote: View Post
We still need an idea what you are willing to spend. Speakers go from a few hundred dollars to $20,000 and more.
Old 04-20-09, 09:11 PM   #13
Alias: Dave
User: #19259
Since: Apr 2008
  dewd is offline
I will say just the opposite. The only reason to mount on a wall is for looks.
Old 04-28-09, 12:26 PM   #14
Alias: damon
Loc: hooper,utah
User: #23603
Since: Jul 2008
  damonb70 is offline
true audio is the ones that carry the bad boy series
Old 04-28-09, 05:00 PM   #15
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
I'm just going to through a few of my personal "truisms"..
  1. Wall mounted or inwall speakers will not sound as good as non-wall mounted speakers at the same price point
  2. Speakers are totally personal -- what will sound good to me might not sound good to you
  3. You can't go wrong with subs from SVS
  4. Do NOT forget acoustical treatments for the room. Properly set up treatments will dramatically improve the imaging and overall sound of a system
  5. Do not buy high priced cables/wire. Buy all of that stuff from monoprice.com or bluejeanscable.com.
  6. Unless you decide to go for separates, I'd buy a receiver from Denon, Yamaha or Onkyo. Find the feature set you like best and buy that one.
  7. A good remote is a great thing to have. Harmony remotes are a good place to look. Pronto or higher end Universal remotes are some others to look at.
  8. A bookshelf speaker will out perform a similarly priced tower speaker.
As for speaker brands, there are tons that I would recommend having a listen to. A short list would include Paradigm, Usher, Monitor, PSB and even the speakers from SVS (although, being online makes that a little more difficult). If you want to step up the price a little, add Dynaudio to the list. The other manufacturers have speakers at all price points, Dynaudio seems to stick to the higher end stuff. If I had wads of cash burning a hole in my pocket, I'd probably be looking at something in their Contour or Confidence lines.
I'm not going to be much help with the choice of projector -- I'd get some opinions here and maybe take a look at what's reported at projectorcentral.com and/or projectorpeople.com. Screens would be another area where I don't have much experience. Carada.com was supposed to be a great online source for screens at a reasonable price.
Finally, I'd read this before auditioning speakers.
Good luck and keep us informed on your progress!
And more importantly, enjoy the process!
"shack", seeking
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
