Home Audio Speakers
Infinity RS 2001
Discuss Infinity RS 2001 in the Manufactured Speakers and Subwoofers forum; Infinity RS 2001 Bought a pair used for $10. Foam on the 6.5's is dead. Foam on the tweets looks marginal but the ...
Views: 569 - Replies: 1
Old 04-25-09, 10:43 AM   #1
Alias: Ampire
User: #29385
Since: Nov 2008
  ampire is offline
Infinity RS 2001
Foam on the 6.5's is dead. Foam on the tweets looks marginal but the tweets work. The foam has deteriorated beyond use on the cones so they need to be refoamed. Should I buy new 6.5's or should I buy a refoam kit? Do these kits look legit? http://cgi.ebay.com/Infinity-RS2001-...QQcmdZViewItem or are there better deals?
Old 04-25-09, 11:24 AM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Infinity RS 2001
I would contact Orange County Speaker. You will pay a little more but are more likely to get the right surround. It is sometimes hard to get a good match when buying surrounds and they have a large assortment and are familiar with most of the brands out there.
http://www.speakerrepair.com/
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
2001, infinity
