| Home Audio Speakers Speaker rot, what causes it?Discuss Speaker rot, what causes it? in the Manufactured Speakers and Subwoofers forum; Speaker rot, what causes it? Ive been seeing several people on forums comment about the speaker rubber surrounds rotting and needing replacement. Why is this ... |
Views: 424 - Replies: 12
| Speaker rot, what causes it? Ive been seeing several people on forums comment about the speaker rubber surrounds rotting and needing replacement. Why is this and is it due to high humidity climates? I have speakers that are almost 18 years old that still have shown no sign of the so called rot problem. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #2 | ||||
| Re: Speaker rot, what causes it? Excellent question Tony- I've been shying away from foam surrounds as they seemed to deteriorate really fast (in a few years sometimes) when I lived on the Gulf coast (TX). Now, you said people are having rubber surround breakdown, hmm...hope someone has the answer ![]() | ||||
| | #3 | ||||
| Re: Speaker rot, what causes it? When you think about it, foam is mostly air, whereas rubber is relatively solid. The rubber will have more stuff to rot away, therefore, will take longer to do so. But, there are probably many other factors involved. One will be more susceptible to oxidation than the other, etc. Besides, a rotted surround is a great way to convince someone to upgrade! Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #4 | ||||
| Re: Speaker rot, what causes it? Not changing your socks after humping all day through the jungle and streams! Always bring dry socks. Seriously though, modern foam and rubber surrounds have coatings that help prevent or at least delay this break down quite a bit. | ||||
| | #5 | ||||
| Re: Speaker rot, what causes it? I dont understand why speaker manufacturers would even make a speaker using foam surrounds I've read that it breaks down so fast in some climates that it needs replacement within as little as 5 years. Now I'm hearing reports that the rubber surround will also break down in some instances. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #7 | ||||
| Re: Speaker rot, what causes it? My understanding is that it is due to a fungus. I suspect that the largest reason for using foam has been to lower costs. It may be lighter as well, and some foam surrounds seem to be more compliant than rubber. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #8 | ||||
| Re: Speaker rot, what causes it? The ones I've seen looked like they were shredded by very sharp claws. ![]() I have since invested in rubber surround drivers and steel speaker grills. | ||||
| | #9 | ||||
| Re: Speaker rot, what causes it? Assuming the speaker is not in a harsh environment (overly humid or lots of smokers), foams and rubbers will age like everything else and dependent on the chemical process, some will do so sooner than later. Even manufacturers that are careful will occasionally have a bad batch (probably the Friday afternoon syndrome). Bob "There is always hope, even if it is just a fool's hope." | ||||
| | #10 | ||||
| Re: Speaker rot, what causes it? In some cases the drivers being asked to produce particularily bad music may cause it. ![]() | ||||
| | #13 | ||||
| Re: Speaker rot, what causes it? I third the bad music one. ![]() but on a serious not, i think some reasons for it is, isnt foam a gasoline based product? So doesnt it dry out more over time. Next, we have the reason of things just wear down over time. Third, when its exposed to constand motion, although not always extreme or continous, it does move. So we have it slowly drying, getting time wear, and expansion and contration wear, I think all of it combined it just causes it to lose its integrity, and cracks and falls apart, becoming brittle. 1x Onkyo TX-SR876(Receiver) 1x Panasonic TH46PZ80U (TV) 1x Polk Audio CSi25 (Center Speaker) 2x Polk Audio R50 (Tower Speakers) 2x Sony SS-U4030 (Surround Speakers) 1x KLH E-12DBN (Subwoofer) Xbox360 + HD-DVD player attachment PS2 (Black Slim Edition), Gamecube (Violet Colored), SNES, N64 (Standard Black Edition) | ||||
