Home Audio Speakers
Newbie looking for advice...can anyone help?
Discuss Newbie looking for advice...can anyone help? in the Manufactured Speakers and Subwoofers forum; Newbie looking for advice...can anyone help? If you have limited space bookshelves can work just fine however for under the $300 price range towers will go ...
Views: 481 - Replies: 29
Old 06-17-09, 02:27 PM   #26
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Newbie looking for advice...can anyone help?
If you have limited space bookshelves can work just fine however for under the $300 price range towers will go deeper (lower frequency response) and as your not getting a sub right away it may be a better choice.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 06-17-09, 02:31 PM   #27
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
tonyvdb wrote: View Post
I have not seen anyone mention the speakers from Yambeka audio.
You miss it (see post #17), I also mentioned Fluance
Old 06-17-09, 02:43 PM   #28
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Sorry David, Missed that.
Home theater:
Two Channel system:
My Webpage
Old 06-17-09, 05:10 PM   #29
Alias: Nate
User: #38662
Since: Jun 2009
  wolfman010 is offline
I really like the Axiom M22, M2 and M3. And also the Athena AS-F2. Thoughts?
Old 06-18-09, 09:30 AM   #30
Alias: Doug
Loc: Juliette, GA
User: #15964
Since: Jan 2008
  DougMac is offline
wolfman010 wrote: View Post
I almost went with Axioms, but I read numerous reviews that found their sound very bright, even harsh. SVS and Ascend offer comparable models at or near the same price point that have as good or better specs and have gotten excellent reviews. I suggest you take a long, hard look at them also. I've dealt with both Ascend and SVS and found them to be very helpful and have been extremely pleased with their products.
Doug
advice...can, help?, newbie
