Home Audio Speakers
help needed
Discuss help needed in the Manufactured Speakers and Subwoofers forum; help needed hi, whats the best speakers to use with a behringer ep 4000 power amp ? cheers...
Views: 156 - Replies: 2
Old 06-16-09, 07:56 PM   #1
Alias: asifq
User: #38292
Since: Jun 2009
  asifqabil is offline
help needed
hi,
cheers
Old 06-16-09, 08:26 PM   #2
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
Re: help needed
A couple of points..
In general, I don't think there is such a thing as synergy with an amp and a speaker. There could be exceptions if we're considering a horn loaded system that is extremely efficient when paired up with a SET tube amp. But, we're talking very specific, almost esoteric, items here.
So, to answer your question, I think whatever you can afford. And what what sounds good to me may not sound good to you. You'd need to audition a few speakers in your budget to find out what sounds good to you. I'm partial to most Paradigm speakers. Others prefer Klipsch or B&W or...
The amp you're referencing is more of a pro version of an amp, so it might not be designed with a home use in mind. It can be used and sound fine, but you sometimes trade off ruggedness and loudness in a pro amp for the more genteel needs of a home system.
Probably not much help, but...
Old 06-16-09, 09:43 PM   #3
Alias: asifq
User: #38292
Since: Jun 2009
Re: help needed
thanx
needed
