Home Audio Speakers
Speaker Recommendation for a newbie
Discuss Speaker Recommendation for a newbie in the Manufactured Speakers and Subwoofers forum; Speaker Recommendation for a newbie I'm new to audio gear in general and am in the process of putting together a system now mostly for ...
Views: 737 - Replies: 24
Old 07-25-09, 03:38 PM   #1
New Member
Alias: dave
User: #39918
Since: Jul 2009
  machajew is offline
I'm new to audio gear in general and am in the process of putting together a system now mostly for playing vinyl.
I'm using a GLi SL 2100 turntable and just ordered an HK 3490 receiver. Can anybody recommend me the best possible speaker setup that I could get around $100-200. Do I have any real options at this pricepoint or should I hold out until I have a little more cash?? used? new?
It's for a pretty small dorm-room type room in a little apartment. I just want something that'll give me really good clear sound without much need for power.
Any info is greatly appreciated!
Old 07-25-09, 04:10 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Speaker Recommendation for a newbie
Hi Dave, Welcome to the Shack.
For your price point the SVS SBS 01 speakers would be a great choice. For the price you won't find anything better.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 07-25-09, 04:25 PM   #3
New Member
Alias: dave
User: #39918
Since: Jul 2009
  machajew is offline
Very cool. Thanks for the recommendation. I want to make sure that I get into something of good enough quality. Would it be better to wait and spend more, or are these speakers that will last and be of good quality?
I also was recommended infinity primus 162s
and infinity beta 20s
Old 07-25-09, 04:28 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
I know the SBS-01's will last years and can very easily be used for surround speakers once you upgrade to larger mains in a 7.1 system.
SVS only sells online and because of this you pay far less than brick and mortar stores will charge.
Home theater:
Two Channel system:
My Webpage
Old 07-25-09, 05:12 PM   #5
Alias: Jay
jackfish's Avatar
Loc: Western Wisconsin
User: #5100
Since: Dec 2006
  jackfish is offline
I'd also consider the Athena LS-100. $200 a pair at Audio Advisor.
The Infinity Primus P162 is also a good value at $170 a pair on sale at Crutchfield. http://www.stereophile.com/standloud...inf/index.html
If you could wait and save up $400 you will definitely get a marked improvement in sound quality.
Old 07-26-09, 04:14 AM   #6
Alias: Kpt
Loc: Edmonton, Alberta
User: #39775
Since: Jul 2009
  KptKrunch is offline
$100 to $200 speakers (new) won't really get you very good sound. That's not to say they'd sound bad, but upping your price a bit would make quite a difference.
for a little over $350 you could get these the Energy RC-30's over at Audioadvisor.
These will give you a much more bass extension than any bookshelf (at $200 or less) and a more fuller sound.
Old 07-26-09, 11:27 AM   #7
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
KptKrunch wrote: View Post
Given he is living in a "pretty small dorm-room type room in a little apartment" bass extension is not a good idea. The SVS SBS-01's go down to 68Hz he would be better off getting a small sub that he can independently adjust the lows.
Home theater:
Two Channel system:
My Webpage
Old 07-26-09, 01:43 PM   #8
Alias: Kpt
User: #39775
Since: Jul 2009
tonyvdb wrote: View Post
Yep - but that's why I'd stay away from a sub. What's the use of getting one if it's so low you can't hear it? And actually, the RC-30 does not produce deep, pounding high SPL bass. Much more subtle than that. It plays low but not overly loud (unless you really crank the volume, can't help that LOL). If you wanted a more impactful bass speaker - you'd need the RC-50 or even the RC-70 (what I have) and then you would have too much speaker for that area (not to mention being way over the OP's budge).
For the price the Energy's are a much better deal (they sold for over a grand in Canadian $'s when they first came out) so if down the road the OP wanted to sell them to upgrade he wouldn't lose much money. The SBS's are what they are, little satellite speakers and would almost have to be given away once used. Plus, the Energy's should be easy enough to find and demo (OP may not like them at all), which can't be said too easily of I.D. speakers. Though for a $200 budget, IMO auditioning is worthless. Any speaker with an original MSRP of $200 or less are what they are. They reproduce sound, but they won't do it very well by audiophile standards, but then again, these aren't exactly going in a dedicated room so what does it matter?
Old 07-28-09, 03:16 PM   #9
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
Welcome Dave. If you are interested, I am selling my SBS-01 speakers. PM me for a good price. Have fun. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 07-28-09, 05:01 PM   #10
jpk
Alias: Joe
Loc: Midwest
User: #6877
  jpk is offline
Welcome aboard Dave.
Another speaker to consider is the AV123-ELT525M’s a 2 way mini-monitor. $175/pr. I did get to hear a pair over the weekend and they’re very nice sounding! Also, they’re not too big for a smaller room. Of course, up to a point spending more will buy better speakers and used can be around half of new. Internet direct dealers also have “B” stock at a savings.
Good Luck with your decision,
Joe
As mentioned, whatever you get can be used later for surrounds, if you go that way.
Old 07-29-09, 02:08 PM   #11
Alias: Doug
Loc: Juliette, GA
User: #15964
Since: Jan 2008
  DougMac is offline
If you can expand your budget slightly, you might want to consider Ascend Acoustics HTM-200 SE (http://www.ascendacoustics.com/pages...00/htm200.html). I have them as rears in a 7.1 system and they sound great. I've listened to them as standalone in a stereo setup and they're fine little speakers.
Will you be listening primarily by yourself or with others? If its personal listening, you might consider buying a nice $100 set of headphones and then save up for speakers. See http://www.goodcans.com/HeadphoneRev...endations.html
Old 07-30-09, 09:02 PM   #12
Alias: Intelonetwo
Loc: Sacramento, Ca
User: #6751
  HionHiFi is offline
Man o man. There is a cherry pair of Vandersteen 1c's (latest model) on the SF Bay Area craigslist. They would make a sweet pair of starter speakers. Seller will take $225 last time I spoke with him.
My2Cents
Old 07-31-09, 11:36 AM   #13
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is offline
For an inexpensive speaker that can be described as crisp and clean, have a listen to the Yamaha NS-6490. I'd imagine they would fit your current needs and budget. These can be found online for less than $100.
Mark
Old 07-31-09, 01:54 PM   #14
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
I would say you have several very good recommendations here. $200 speakers are very hard to find. Keep an eye on Audiogon for some really good deals on used speakers. I hate that place because it makes me spend WAY TOO MUCH money.
Paradigm Atom v. 6 $248 OBO
Focal JM Lab 707 $250
B&W DM302 $175 OBO
Linn Index $250 OBO
Rega R1's $279
Tannoy Mercury F1 $225 OBO
Paradigm ADP-150 $200
Definitive Technology BP 1.2x $235
Av123 XLS Encore $235 OBO
Swans D2.1SE $375 OBO
Quad 11L2 $385 OBO
Harbeth Monitor 40.1 $12,995
Please keep me away from that place.
Old 07-31-09, 01:56 PM   #15
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Sonnie wrote: View Post
Good one Sonnie
Home theater:
Two Channel system:
My Webpage
Old 07-31-09, 04:53 PM   #16
Owner
  Sonnie is offline
What... Everyone needs a pair or two of the Harbeth's.
Old 07-31-09, 05:07 PM   #17
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
I'v actually never heard of them so I have no idea if they really sound like $13,000 something tells me they are a bit over priced.
Home theater:
Two Channel system:
My Webpage
Old 07-31-09, 11:08 PM   #18
Alias: Jay
jackfish's Avatar
User: #5100
Since: Dec 2006
  jackfish is offline
Yeah, apparently you haven't heard them. They may be out of one's price range but when compared to less expensive loudspeakers, and others costing the same, their value becomes evident. However, at that price, and if they were still available, I'd go for a pair of Meadowlark Blue Heron IIs.
Old 08-02-09, 03:05 PM   #19
Alias: Greg
Loc: Denver, CO
User: #55
  GregBe is offline
Sonnie has great advice. For your price range, I would definitely look at used. Nothing wrong with used speakers. I have done it before and will do it again.
Old 08-09-09, 11:31 AM   #20
Alias: Maceo23
Loc: Houston, TX
User: #7526
Since: Mar 2007
  Maceo23 is offline
If you're anywhere near San Fran, get the Vandersteen 1c's! They are a steal at retail price, $225 is just retarded.
Old 08-18-09, 03:19 PM   #21
Alias: Glen
User: #40844
Since: Aug 2009
  Glenee is offline
Try Usher 520s
Old 08-20-09, 07:10 PM   #22
Shack Moderator
Alias: Jack
Loc: Sarasota, Florida
User: #40011
Since: Jul 2009
  Jungle Jack is offline
Hello,
Sonnie's recommendations are spot on. Paradigm especially makes an excellent value speaker. I am also quite fond of PSB which is another Canadian company.
The Canadian companies have benefited greatly by Government funded subsidies and research facilities. If you could find a used pair of PSB Image 4T's, you would have a speaker which is comparable to speakers which cost multiples of its asking price.
If you could stretch your budget, these PSB Stratus Silver i's:http://cgi.videogon.com/cgi-bin/cl.p...ain&1255286287, are 2 thousand dollar speakers. Even at the original asking price they provided stunning value.
Without question, if having to stay in the 100-200 Dollar range, used is the only way to get anything worth owning.
Cheers,
JJ
Old 10-06-09, 07:42 PM   #23
Alias: Walt
walmat's Avatar
Loc: Toronto
User: #41799
Since: Sep 2009
  walmat is offline
Listen to the PSB's. They're very affordable and even the lower lines sound great.
Rock n' Roll All Nite and watch blus everyday
Old 10-06-09, 09:30 PM   #24
Shack Moderator
Alias: Jack
User: #40011
Since: Jul 2009
Hello,
PSB's are an excellent alternative. Check out Upscale Audio. Kevin Deal the owner is semi famous and carries some amazing lines. Especially tubes. Moreover, he sells B Stock PSB Speakers for excellent prices. Add dot.com to his store and you will see the website.
A great thing about PSB is that they are not so rabidly against mailorder like Paradigm is and still makes excellent speakers. Most of the Canadian companies are awesome values due to Canada's investment in helping Speaker Companies flourish.
Cheers,
JJ
Old 11-01-09, 10:33 AM   #25
New Member
Alias: jung
Loc: Minneapolis
User: #41976
Since: Sep 2009
  jung4g is offline
B&W DM302 $175 OBO
I highly recommend these as well. I've got two pair matched with a CC3 center for my 5.1 setup. They sound amazing in a smaller space, but with a sub added and a 80-90Hz Crossover, they really open up. Very good clarity, and not a fatiguing sound at all. Plus they're small enought that the wife is cool with them.
newbie, recommendation, speaker
