Home Audio Speakers
Mission 76x speaker line information
Discuss Mission 76x speaker line information in the Manufactured Speakers and Subwoofers forum; Mission 76x speaker line information Below is all the information I have found or have on the Mission 76x speaker line including specifications and some ...
Views: 501 - Replies: 1
Old 08-06-09, 11:26 PM   #1
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Below is all the information I have found or have on the Mission 76x speaker line including specifications and some photos.
The Mission 76x speaker line was made in England by the Mission Cyrus Group and distributed in North America by Mission electronics INC in Vancouver Canada and was manufactured between 1989 through 1992. Information seems to be very hard to come by now as well as parts.
Some have said that this and the 75x line were Missions best speaker lineup particularly the 764-767
If you are looking for parts you can contact the only Mission sales contact I have found AUDIONINE in Toronto Canada by email
Specifications:
760's
2 way reflex
Frequency response: 60Hz-20KHz
Impedance: 6 Ohm
Sensitivity: 89db
20-75Watts
Max SPL: 103db/pair
Crossover: 4.5KHz
Effective volume: 6.5L
Drive units: HF; 19mm (.8") fabric dome FF cooled, LF; 135mm (5.5") Plasiflex
Input connector: spring clip
Cabinet dimensions 295x180x200mm (11.6x7x7.9")
Weight: 7kg (15.4Lbs)
Finish: Black ash
761
2 way sealed
Frequency response: 58-20KHz
Impedance: 6 Ohm
Sensitivity: 89db
20-75Watts
Max SPL: 104db/pair
Crossover: 4.2KHz
Effective volume: 11L
Drive units: HF; 19mm (.8") fabric dome FF cooled, LF; 175mm (7") Plasiflex
Input connector: 5 way post
Cabinet dimensions 380x210x220mm (15x8.2x8.6")
Weight: 12kg (26.4lbs)
Finish: Black ash
762
2 way reflex
Frequency response: 50-20KHz
Impedance: 8 Ohm
Sensitivity: 93db
20-100Watts
Max SPL: 106db/pair
Crossover: 4.3KHz
Effective volume: 23L
Drive units: HF; 19mm (.8") fabric dome FF cooled, LF; 210mm (8.7") Plasiflex
Cabinet dimensions 500x250x283mm (18.5x9.8x11.1")
Weight: 21kg (46.2lbs)
Finish: Black ash
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 08-06-09, 11:26 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Mission 76x speaker line information
763
No photo currently
2 way reflex Bi-amp/Bi-wire
Frequency response: 45-20KHz
Impedance: 8 Ohm
Sensitivity: 89db
25-125Watts
Max SPL: 108db/pair
Crossover: 3.2KHz
Effective volume: 43L
Drive units: HF; 19mm (.8") fabric dome FF cooled, LF; 200mm (8") Diecast polypropylene
Cabinet dimensions 770x250x338mm (30.3x9.8x13.3")
Weight: 32kg (70.5lbs)
Finish: Black ash
764
Frequency response: 42Hz-20KHz
Impedance: 8 Ohm
Sensitivity: 88db
25-150Watts
Max SPL: 109db/pair
Crossover: 3KHz
Effective volume: 48L
Drive units: HF; 25mm (1") Dicast fabric dome IMP transformer dome, LF; 210mm (8.3") Dicast Homopolymer
Cabinet dimensions 860x250x338mm (34x9.8x13.3")
Weight: 40kg (88.1lbs)
Finish: Black ash
765
Frequency response: 39Hz-20KHz
Impedance: 4 Ohm
Sensitivity: 93.5db
25-200Watts
Max SPL: 111db/pair
Crossover: 3.2KHz
Effective volume: 50L
Drive units: HF; 25mm (1") Dicast fabric dome IMP transformer, LF; 2 times 210mm (8.3") Diecast polypropylene
Cabinet dimensions 950x260x320mm (37.4x10.2x12.5")
Weight: 46kg (101.4lbs)
Finish: Black ash
767
3 way reflex Tri-amp
Frequency response: 22Hz-20KHz
Impedance: 8 Ohm
Sensitivity: 92db
50-350Watts
Max SPL:
Crossover:
Effective volume:
Drive units: HF; 25mm (1") Dicast fabric dome IMP transformer, LF; 2- 8" bass Dicast Homopolymer, 2- 6" midrange Dicast Homopolymer
Cabinet dimensions
Weight: 86kg (189.5lbs)
Finish: Black ash
The 767s required a special external crossver (LFAU) along with the Cyrus amp in order to run them properly and are very hard to find.
"The Low Frequency Alignment Unit (LFAU) was originally designed around the award wining Cyrus II integrated amplifier for the primary use with the Mission 767 loudspeakers. The LFAU was a dedicated amplifier for the bass units of the 767 and the remainder of the units were controlled by a standard integrated amplifier. The controls on the LFAU differ from those of a standard amplifier as the bass response of the 767 system could be fine tuned to suit the listening environment."
A PDF of the LFAU setup and instructions located here
Home theater:
Two Channel system:
My Webpage
information, line, mission, speaker
