| Home Audio Speakers Recommend Rear Cntrs for 7.1?Discuss Recommend Rear Cntrs for 7.1? in the Manufactured Speakers and Subwoofers forum; Recommend Rear Cntrs for 7.1? Can you recommend a pair of in-wall or small rear speakers to use in a 7.1?. These are the rear ... |
Views: 667 - Replies: 0
| Recommend Rear Cntrs for 7.1? Can you recommend a pair of in-wall or small rear speakers to use in a 7.1?. These are the rear center pair of surrounds. These are not ideally located as they will be above windows about 80" at top. So if in-walls hopefully there is some way to aim them down towards the listening position. I mounted by bookshelves on that wall but the are esthically too big and ruin the balance of the room. My other speakers are Acoustic Research L,R&C. The two side sorrounds and JBL in-wall (2 way) with 6.5inch woofer and fixed position tweeter. Any thoughts appreciated and a way to go here. thanks! . | ||||
