Home Audio Speakers
help in wall speakers or orb audio
Discuss help in wall speakers or orb audio in the Manufactured Speakers and Subwoofers forum; help in wall speakers or orb audio Hello I’m building a new home with pre wired for 7.1 surround sound in the ceiling .I’m thinking about getting ...
Views: 342 - Replies: 16
Old 08-16-09, 08:24 PM   #1
Alias: davo
Loc: st pete
User: #25109
Since: Sep 2008
  big7ben7 is offline
Hello I’m building a new home with pre wired for 7.1 surround sound in the ceiling .I’m thinking about getting in -Wall speakers or orb audio speakers .I have some different ones I’m looking at see below .But would like some feedback ..
http://www.orbaudio.com/index.asp?Pa...PROD&ProdID=32
http://www.bestbuy.com/site/olspage....=1151658127370
http://www.shopallelectronics.com/Na...d=DGBuWEOnvaQ=
http://www.htd.com/in-wall-ceiling-s...s#ReviewHeader
onkyo 650
4 buttkickers
onkyo ht 6100 7.1
samsung ln650a
playstation 3
driectvhddvr
sonicview
Old 08-16-09, 08:31 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: help in wall speakers or orb audio
Give this thread a good read before you go that route, You may want to rethink your decision.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 08-16-09, 09:14 PM   #3
Alias: davo
Loc: st pete
User: #25109
Since: Sep 2008
  big7ben7 is offline
Thanks tonyvdb .I read your post .Thank you for your insight .I really don’t want anything big bulky .And I know nothing about in wall speakers or these orb audio so im just fishing around to see what would fit my my situation.
Old 08-16-09, 09:29 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
It can sometimes be a compromise, dont get to concerned about it.
Are you willing to try at last getting some decent front speakers? How much do you think you want to spend on speakers.
Home theater:
Two Channel system:
My Webpage
Old 08-16-09, 09:33 PM   #5
Alias: davo
Loc: st pete
User: #25109
Since: Sep 2008
  big7ben7 is offline
I could spend about 1500 .
Old 08-16-09, 09:39 PM   #6
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Does this include a subwoofer? I really like this package. for the money its a great deal and they sound fantastic. You could upgrade the sub to something a bit larger and still stay in your budget.
Home theater:
Two Channel system:
My Webpage
Old 08-16-09, 09:41 PM   #7
Alias: davo
Loc: st pete
User: #25109
Since: Sep 2008
  big7ben7 is offline
How would you position the speakers 7.1 surround sound in a living room is 16x19 .How far should my couch be back from the back wall with the 2 speakers .How far should the 2 speakers on the sides of me be positioned if hung on the ceiling ?
Old 08-16-09, 09:46 PM   #8
Alias: davo
Loc: st pete
User: #25109
Since: Sep 2008
  big7ben7 is offline
That does look nice
This is what I have now.
Amazon Amazon
But I have a 1 year old keeps knocking the speakers off the stands and have another one on the way in 3 months .So that’s another thing to get the speakers off the ground.
Old 08-16-09, 09:47 PM   #9
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
You can place the rear and side speakers about 7' off the floor and angle them down so they point at the area in front of the seating position. Look here for ideal positioning.
Home theater:
Two Channel system:
My Webpage
Old 08-16-09, 09:52 PM   #10
Alias: davo
Loc: st pete
User: #25109
Since: Sep 2008
  big7ben7 is offline
thank you for the link
Old 08-16-09, 09:55 PM   #11
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
big7ben7 wrote: View Post
That does look nice
http://www.amazon.com/Onkyo-HT-S6100.../dp/B001AMY7ZQ
Thats a good starter system, The receiver will do you for the time being. I understand the speaker with kids problem as my 2 year old has done damage to my $1800 speakers but I repaired them without any damage. by mounting them higher up that is going to help, its not ideal for the fronts but in your situation it is a satisfactory compromise. Is the room your using already dry-walled and finished? You could build them into coves into the wall and cover them with a white thin cloth as long as the leading edge of the speaker is sticking out just a little bit you wont change the sonics of the speaker too much.
Home theater:
Two Channel system:
My Webpage
Old 08-16-09, 10:06 PM   #12
Alias: davo
Loc: st pete
User: #25109
Since: Sep 2008
  big7ben7 is offline
No they haven’t started building but I need all specs where I want to put everything by the end of the month for contracting purposes .I’m just wondering if the orb audio is the way to go .I know im sacrificing some but I have to do what I got to do .I f you had to what in wall speakers would you get I could go a little higher if I had to.
Old 08-16-09, 10:10 PM   #13
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Good quality in walls cost about two or three times as much to get the same quality. I dont have knowledge of any that I would recommend however if you can find some that have tweeters that swivel that is a big improvement as you can angle them to point at where you sit.
Home theater:
Two Channel system:
My Webpage
Old 08-18-09, 10:44 AM   #14
Alias: davo
Loc: st pete
User: #25109
Since: Sep 2008
  big7ben7 is offline
What do you think about these ?
Amazon Amazon
Old 08-18-09, 10:54 AM   #15
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
I have heard that they are a decent product. The tweeter does swivel so thats a good thing.
Home theater:
Two Channel system:
My Webpage
Old 08-18-09, 12:26 PM   #16
Alias: davo
Loc: st pete
User: #25109
Since: Sep 2008
  big7ben7 is offline
if you could get these for 200.00 as piece would you do it?
Amazon Amazon
Old 08-18-09, 02:40 PM   #17
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
They are a good speaker for $200. I personally could not go with in walls or in ceiling speakers but thats just my choice. Its up to you.
Home theater:
Two Channel system:
My Webpage
audio, speakers, wall
