Home Audio Speakers
Onkyo SKS-HT540 Stand Advice needed
Discuss Onkyo SKS-HT540 Stand Advice needed in the Manufactured Speakers and Subwoofers forum; Onkyo SKS-HT540 Stand Advice needed I bought the Onkyo SKS-HT540(B) 7.1 Speaker set a month ago and am finally getting around to putting them together. ...
Views: 167 - Replies: 3
Old 09-14-09, 04:45 PM   #1
Alias: Dan
User: #39255
Since: Jul 2009
  spartan789 is offline
I bought the Onkyo SKS-HT540(B) 7.1 Speaker set a month ago and am finally getting around to putting them together. I'm looking to get stands. Can anyone give me any recommendations? TIA.
*Mods, if this is in the wrong section, please move it. Thanks*
Old 09-15-09, 01:15 PM   #2
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
Re: Onkyo SKS-HT540 Stand Advice needed
I haven't used these before but they have good reviews, especially considering the $$: http://www.monoprice.com/products/pr...t=1#largeimage
They'd be sturdy and tall enough to use with your surrounds, but not the fronts. For your fronts/center, I'd set them on the same entertainment center that you're using for your TV, or if your TV is mounted to the wall, do the same with the speakers using monoprice speaker mounts.
Old 09-15-09, 02:52 PM   #3
Alias: Dan
User: #39255
Since: Jul 2009
Actually, from the reviews I've read they might not hold my surrounds very well. Mainly because of the size (surrounds in that set are 10.5" tall). I usually love stuff from Monoprice, but I don't think those would work. Any other good places to look?
Old 09-15-09, 03:34 PM   #4
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
You're right, I did not look close enough at the onkyo speaker specs. I saw 3.5" woofer and assumed the cabinets would be no more than 6-7" tall.
If you're looking for cheap and sturdy with a huge amount of adjustment, I like these: http://accessories.musiciansfriend.c...ree?sku=452067
I have a pair still in boxes planning to use them for monitors when we get settled in our new digs. The aesthetics aren't for everyone, and some users complain of wobble where other claim they are rock solid (I haven't assembled mine yet), but looking at the design, they should be sturdy.
Onkyo also makes a set of speaker stnad which might work, though their height is unclear. The AS240.
The hardest part with surrounds is finding something 42"+ tall. There are very few pre-made options out there. Over the years, I've used tall bookshelves, wall mounting, and even put the surrounds on the floor shooting upward (that last option actually isn't too bad, using it at my parents place right now where they have a reflective wall behind them).
If you're at all handy with tools, you might consider making your own out of wood or pipe. You could consider your stand doing double duty as a bass trap in a similar way to the GIK Pillar Trap. You could also take a 32" premade trap and just build a 12-24" base for it.
Keep us updated on what you find.
advice, needed, onkyo, sks-ht540, stand
