| Home Audio Speakers Went used speaker hunting today at the pawn shopsDiscuss Went used speaker hunting today at the pawn shops in the Manufactured Speakers and Subwoofers forum; Went used speaker hunting today at the pawn shops I got a infinity surround speaker for 10 bucks .. Everything works gret the only thing is i need to ... |
Views: 628 - Replies: 31
| I got a infinity surround speaker for 10 bucks .. Everything works gret the only thing is i need to resurround the woofers .. I found a kit for 29.00 online .. so thats a pretty good deal ... the wood and cover are spotless .. I will get some pics.. The Specs are Model : RS video black -:®:- Frequency Response : 100 Hz - 25 KHz +3dB -:®:- Crossover Frequency : 2200 Hz -:®:- Sensitivity : 89 dB @ 2.8V -:®:- Impedance : 8 Ohms -:®:- Power Rating : 20 - 150 watts RMS into 8 Ohms -:®:- Woofers : 5 1/4" [ x 2 ] -:®:- Tweeter : 1" Ferrofluid Cooled Polycell -:®:- Cabinet : Black Ash -:®:- Dimensions [ W x H x D ]: 465 x 115 x 120mm -:®:- Weight : 4.5kg Only 1 ? the refoam kit says 5 inch and that it will fit my speaker model 902-6416 HMMM so is it a 5inch or 5.25 inch ... Or should I just get new speakers for it .. The tweet is in mint condition.. | ||||
| | #2 | ||||
| Re: Went used speaker hunting today at the pawn shops 10 bucks plus 30 for repair kit? Nice!!! Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx | ||||
| | #3 | ||||
| Re: Went used speaker hunting today at the pawn shops That sounds like a great bargain-say, will those new surround kits bring the woof back up to spec? Which kit are you using/considering? Anyone know which are best/best value? | ||||
| | #4 | ||||
| Re: Went used speaker hunting today at the pawn shops Ok here it is I have been cleaning the woofers for about 2 hours... One thing that worries me is they say to remove the dust cap and use shims but these woofers it looks impossible to do because the dust caps are flat .. | ||||
| | #5 | ||||
| Re: Went used speaker hunting today at the pawn shops Should I try to get the dust covers off are just take a chance and put the surrounds on and be real careful ??? The cover for this that is not pictured is in mint shape as well so if the speakers turn out a little ugly you will not be able to tell ... The woofers are 4 ohms and they were wired in series then too a crossover and the Ferrofluid Cooled Polycell tweeter is in mint shape ... Dang I am really worried about trying to get the dust caps off??? Do I have too shim it and take the dust caps off ? | ||||
| | #6 | ||||
| Re: Went used speaker hunting today at the pawn shops I've never done a re-surround, but seems to me that shimming would center the voice coil and thus enable the re-surround most accurately. Otherwise, if you glue the surround to the cone first, let dry, then apply the glue to the frame, followed by pushing the surround into the wet glue while the driver is perfectly level, it seems that would be a good method. Perhaps someone else has done this successfully? ![]() | ||||
| | #7 | ||||
| Re: Went used speaker hunting today at the pawn shops Well I decided to remove the dust cover .. it was a slow process but probably well worth it .. I used a little thinner and rubbing alchol and a razor blade .. Took me about an hour to get this one off .. | ||||
| | #8 | ||||
| Re: Went used speaker hunting today at the pawn shops After removing both dust caps , I really see the need to shim before putting on the new surround because with out the surround the coil moves everywhere.. And if you are off one MM of an inch you will have to start all over .. so now I am going to shop for the new surround .. I think I am going to go with a woofer rubber surround instead of the cheap foam that was on it originally... More to come | ||||
| | #9 | ||||
| Re: Went used speaker hunting today at the pawn shops Sorry I missed this thread. I could have saved you some time. I have done many of these and found that rather than removing the dust cap, I can get more perfect centering by leaving it, and not risk getting dust and debris in the gap. What I do is use a slow drying glue (my favorite is WelBond) and start by gluing the surround to the cone. The slow drying lets me get the centering as even as possible. Once that dries, if you put a weight on the cone (use a smaller speaker) to push it down slightly, it lifts the outer edge of the surround off of the basket, allowing a bead of glue to be run along the inner edge of the basket under the surround. Then release the weight and let the cone rise up. The coil will be very close to centered in the gap if you are careful to place the weight inthe center because of the tension from the spider. Tamp down the outer edge, then as the glue is drying you can move the cone up and down to verify that there is no scraping of the coil on the poles. The slow drying glue lets you center it if needed. The problem with shimming the gap is that you can get some uneven surrounds or pulling due to glue drying, and still get an off center job. You also have to be very careful not to get dust in the gap. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #10 | ||||
| Re: Went used speaker hunting today at the pawn shops OOPs .. I guess if they screw up I could get some Dayton's and throw in there but i am tring to keep it all orginal .. I guess i Could glue the caps back on .. and I have a couple of old cv tweets I could set in the center of the speakers for weight ... I may try the shims .. my biggest problem with these 902-6416 speakers is that they are 4 ohm and hooked in series in the cabinet.. It is a center channel infinity .. And it is hard to find good 5.25 inch 4 ohm home speaker replacements.. Since I have already got the dust caps off should I shim it or just put the caps back on and try it with weight and slow drying glue..? | ||||
| | #11 | ||||
| Re: Went used speaker hunting today at the pawn shops Here are a couple of cheapy's at PE that are 4 ohm , But isn't Goldwood the cheap speaker you get at rent a center's ?? The rated rms wattage is good and the freq range is pretty close to the infinity's but not sure about the construction | ||||
| | #12 | ||||
| Re: Went used speaker hunting today at the pawn shops If you already have the caps off, just go ahead and shim it. It is the easiest way to do it. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #14 | ||||
| Re: Went used speaker hunting today at the pawn shops For the surrounds themselves or for the service to replace them? Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #16 | ||||
| Re: Went used speaker hunting today at the pawn shops The surrounds are tough, unless you want to pay $20+ for the kits. I have gotten them from MAT and from a handfull of others that have them intermittently, but currently have no good suppliers for you other than recommending the folks who repair them. Some will sell them separately as parts, some will not. The main supplier that most use only sells to speaker repair shops and will not sell retail. Look in the thread here for speaker repair shops: http://www.hometheatershack.com/foru...e-centers.html Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #17 | ||||
| Re: Went used speaker hunting today at the pawn shops http://cgi.ebay.com/Infinity-5.25%22...QQcmdZViewItem This is what I am ordering since PE doesn't carry 5¼ inch kits | ||||
| | #18 | ||||
| Re: Went used speaker hunting today at the pawn shops How many surrounds have you done. I would just remove it and get it right. I have done close to 100. The shims allow for easy work. I can offer some advise if you like. PM me for cell if you need help. | ||||
| | #19 | ||||
| Re: Went used speaker hunting today at the pawn shops Thanks Robert I may have to do this .. This will be my first .. And if I mess it up I can probably find some good 5.25's somewhere.. I was just wanting to use the orig. because that is what the enclosure was built for.. | ||||
| | #20 | ||||
| Re: Went used speaker hunting today at the pawn shops I ordered the surround repair kits today they are made for my infinity 5.25 RSVIDEO center channel speakers I got them from GeoAli Vintage Stereo and More... http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123 I hope they work.. Now just got to wait a few business days .. I am really dying to try out this nice infinity RSVIDEO center cahnnel | ||||
| | #22 | ||||
| Re: Went used speaker hunting today at the pawn shops ![]() Well they dried and they look like they are gonna work , I removed the shims and as far as I can tell they move up and down and the voice coil doesn't scrape at all so I put the dust caps back on. here are some pics before they go in the housing. | ||||
| | #23 | ||||
| Re: Went used speaker hunting today at the pawn shops And just now I mounted them in the Center Speaker Housing .... I probably need to wait a while before I hook them up because the dust caps glue is still a little tacky... but here you go .. I bought it for 10.00 at the pawn shop and then paid 17.36 for the foam surround from ebay and for 27.36 I have this..![]() ![]() | ||||
| | #25 | ||||
| Re: Went used speaker hunting today at the pawn shops Good job. How does it sound? | ||||
