Home Audio Speakers
Bose speakers.......
Discuss Bose speakers....... in the Manufactured Speakers and Subwoofers forum; Bose speakers....... I've been browsing around here a long time and it seems that BOSE speakers have a bad rap... My only ...
Views: 631 - Replies: 36
Old 10-22-09, 02:07 AM   #1
Bronze Supporter
Alias: Panaman
panaman's Avatar
Loc: Delaware Ohio
User: #30397
Since: Dec 2008
  panaman is offline
My only complaint is that, I haven't seen anything else that can compete with the bose sound/size.
Maybe I am a noob.......I have some pretty small Energy speakers.. but I have heard some friends bose speakers and they make my Energys cringe..... and my energy speakers are probably twice the size.
42" Insignia 1080P LCD, LG BD370 Bluray Player, Onkyo TX-SR507 Receiver (5.1), Energy Take Classic 5 pack Home Theater System, Sony SA-WM500 12" Subwoofer
Old 10-22-09, 03:25 AM   #2
Shack Moderator
Alias: John
recruit's Avatar
Loc: UK - Near London
User: #37302
Since: May 2009
  recruit is online now
Re: Bose speakers.......
Hi panaman, yes Bose speakers are not Ideal and tbh are expensive for what they are, although they are fairly capable for such small speakers, I owned a pair many years ago and they appealed to me because of there size...it is only when you get to listen to full range speakers do you then realise how much sound you are really losing and I could not settle for anything less now.
If you are looking for a discrete install and WAF comes into it then a lot of people do choose BOSE because of this, although I would be more inclined to go for inwall speakers if I had the choice.
Edit: If you want small then the MKSound Xenon range would be a better choice as it has superior sound to BOSE imo
Old 10-22-09, 10:17 AM   #3
Bronze Supporter
Alias: Panaman
panaman's Avatar
Loc: Delaware Ohio
User: #30397
Since: Dec 2008
  panaman is offline
hey thanks for the tip...
do you know where one would be able to hear a set of MKSound Xenon
Old 10-22-09, 10:22 AM   #4
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
The Dolphin Group now distribute MK speakers in the US, the link gives info for dealerships and contact details...
http://www.thedolphingroup.org/
Old 10-22-09, 10:27 AM   #5
Bronze Supporter
Alias: Panaman
panaman's Avatar
Loc: Delaware Ohio
User: #30397
Since: Dec 2008
  panaman is offline
that sux..... there are none close to me
Old 10-22-09, 10:27 AM   #6
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Have a look at this post here as it explains why Bose and other products like them are not ideal.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 10-22-09, 10:31 AM   #7
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
tonyvdb wrote: View Post
excellent thread Tony
Old 10-22-09, 10:35 AM   #8
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
I think the big thing is that Bose cube speakers and ones like them are not full range systems as they have a big hole in the frequency response between about 150Hz and 300Hz and do not go lower than 40Hz with the bass cube.
Home theater:
Two Channel system:
My Webpage
Old 10-22-09, 10:39 AM   #9
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
exactly, they can sound impressive for there size but there are better solutions availible with all the frequency range intact...
Old 10-22-09, 11:02 AM   #10
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
If I had access to some I would put them through REW and that would tell a very clear story.
Back in the 80's The Bose 901, 801's and so forth were actually very nice sounding speakers the problem was that they were WAY over priced for what they were and you needed that stupid proprietary Bose EQ with them for them to work properly .
Home theater:
Two Channel system:
My Webpage
Old 10-22-09, 12:07 PM   #11
Alias: Doug
Loc: Juliette, GA
User: #15964
Since: Jan 2008
  DougMac is offline
Ya canna change the laws of physics, Jim!
Even if the small Bose speakers were well engineered (which they're not), made from quality components (which they're not) and reasonably priced (which they're not), you can't get around the limitations imposed by their size.
If you have to go with smallish speakers, look at offerings from Ascend and SVS. I use the Ascend HTM 200's for rear surround in my HT and they're really nice sounding speakers. I tested them as mains in a sub/sat configuration and was impressed at how good they can sound. I've also read some good reviews of the small SVS speakers. Contrary to Bose, they are well designed, well built and reasonably priced.
Old 10-22-09, 12:56 PM   #12
Alias: Zip
MatrixDweller's Avatar
Loc: Canada
User: #10408
Since: Jul 2007
  MatrixDweller is offline
Paradigm Atoms or Definitive's small speakers are much more impressive. Better quality, better performance, better price.
Bose is marketed towards the generation of consumers who couldn't figure out how to set the clock on their VCRs (Baby Boomers).
Old 10-22-09, 12:57 PM   #13
Shack Moderator
Alias: Jon
Loc: Irvine, CA
User: #9090
Since: May 2007
  Jon Liu is offline
Just like Doug said, "Ya canna change the laws of physics, Jim!"
Sound in general is essentially just a movement of air (over generalization, probably) but size does matter. Is size everything? No, but again the tiny jewel cubes that Bose has and their Bass module simply cannot move that much air so they sacrifice on certain aspects, i.e. high and low end of the frequency spectrum.
Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx
Old 10-22-09, 01:49 PM   #14
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
So most of the reasons why we rant against Bose have already been stated. If you want to see something in detail, this site does a pretty good job.
If you NEED to go small, I've heard Orb speakers are pretty decent. They're still expensive IMO, but not the outright robbery that Bose is and they're supposed to be better.
Old 10-22-09, 07:59 PM   #15
Shack Moderator
Alias: Jack
Loc: Sarasota, Florida
User: #40011
Since: Jul 2009
  Jungle Jack is offline
Hello,
Sadly, there is a reason that there is an adage; no highs, no lows, must be Bose. The Intellexual thread about Bose really hammers home why so many audio lovers are not fans of Bose.
My personal biggest issue is that they seem to spend more on marketing and litigation than they do on engineering. They are doing a stellar job as millions are brainwashed that Bose equates with great sound.
I do have an issue with people who insult those who own their wares just the same. AVSForum is downright nasty to most anyone who says that they own Bose. This is not the way to help an individual make a different decision in the future. It is just at the prices that Bose Systems go for, it is extremely easy to provide alternatives which are far more faithful to the source signal.
Cheers,
JJ
Old 10-23-09, 02:15 AM   #16
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
Other small speakers that should outperform Bose at a fraction of the price:
RBH CT Series
Audioengine P4 (A2 is you don't need to get to Rock&Roll dBs)
PSB LR1
Old 10-23-09, 03:38 AM   #17
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
I know of many people who are more than happy with there Bose speakers and although they enjoy watching movies they have no intention of changing them because it satisfies there needs for what they want, there is a market clearly for them and that is the way it is, but when you want more then that is when you understand the limits of Bose systems, that is why it is great to have forums like this so we can give advice to prospective buyers and let them know the facts of why so many people are put off by them and there limits...
Old 10-23-09, 09:15 AM   #18
Alias: Doug
Loc: Juliette, GA
User: #15964
Since: Jan 2008
  DougMac is offline
Tonight will be interesting. We're having some friends over for movie night. One of my friends has a living room home theater setup with some sort of Bose system for the sound. He asked me what kind of sound system I had. How do you explain? Saying I've got Ascends with an SVS subwoofer means absolutely nothing to the general populace. If it's not in the big box store, it doesn't exist.
I'm interested in his impressions. I'm certainly not interested in "converting" him, and the last thing I'd do is point out the defeciencies of the Bose he owns. Furthermore, his system may be perfectly adequate for his needs. He and his wife have a very tastefully decorated living room and the speakers in my dedicated HT would be out of place in his home.
Of course I think he could buy a system that would be scarcely more noticeable, but think of the effort involved to find it. The closest decent audio store is 85 miles away in Atlanta. He, as most of my friends, would be clueless about how to hunt down decent audio on the web. You're not likely to hunt down something you don't know even exists. If, after his visit tonight, he asked about how to get better sound, I'll point him in the right direction.
Old 10-23-09, 09:51 AM   #19
Shack Moderator
Alias: Jack
User: #40011
Since: Jul 2009
Hello,
Doug, hopefully this will be illustrative to the gathered masses. I would imagine feeling and listening to true low frequency information will be an epiphany to your friends.
Look forward to hearing their comments.
Cheers,
JJ
Old 10-23-09, 10:26 AM   #20
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
I always love seeing the look on peoples faces as they feel there cloths literally vibrate on their body when they are at our house for the first time to see a movie, their smile says it all
Home theater:
Two Channel system:
My Webpage
Old 10-23-09, 02:43 PM   #21
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
DougMac wrote: View Post
Look forward to what you friends have to say after the showing, I remember when I had my M&K 850 system and a friend had the Bose Acoustimass 15 speaker package, he heard mine and wanted some, infact when I put them up for sale to upgrade he promptly bought them off me...
Old 10-24-09, 11:44 AM   #22
Alias: Doug
Loc: Juliette, GA
User: #15964
Since: Jan 2008
  DougMac is offline
Jungle Jack wrote: View Post
Hello,
Cheers,
JJ
His jaw dropped. He couldn't believe the difference. He can't wait to come back and hear more. We had several couples over and the movie we watched was not conducive to showing the true capabilities, so he only got a taste. He wants to come back and watch something that will exercise the sub more, like "Master and Commander" or "The Dark Knight".
Everyone was bowled over by the entire package. They couldn't get over how good blu ray looks when projected. More than one stated they'd much rather watch movies in my HT than at any of the local theaters. They're already conspiring to have regular movie nights. They're a great bunch and I'm all for it.
Old 10-24-09, 05:17 PM   #23
Shack Moderator
Alias: Jack
User: #40011
Since: Jul 2009
Hello,
Play him Transformers 2: Revenge of the Fallen. While a movie lacking story, plot, and pace, it is one of the most impressive DTS-MA Soundtracks ever. Every professional reviewer has pointed out that it might be the loudest Blu Ray ever. They say maybe even too much of a good thing. Bass especially.
I am glad to hear your Bose owning friends were blown away by the difference between a system which reproduces the entire frequency response and one which uses psychoacoustical tricks and only emphasizing the midrange.
Cheers,
JJ
Old 10-24-09, 10:55 PM   #24
Alias: Zip
Loc: Canada
User: #10408
Since: Jul 2007
I've had the same reaction many times, even with my older less robust Cerwin Vega system.
A buddy that I worked with back in 1999 (horrible that it seems so long ago) had bought a Bose cube system and thought it was the cat's meow. I too at the time thought that Bose was a good brand name. I didn't really know anything back then and thought the idea of direct reflecting speakers was kind of neat. Bose had a lot of cool literature and a lot of the people I talked to, that I thought were knowledgeable, liked Bose. I stayed clear of Bose though because they were a little too expensive for me at the time.
So I pieced together a system by picking up a center and surrounds at a pawn shop, a clearance Kenwood receiver and Pioneer DVD player from a big box store and a pair of Cerwin Vega towers half price at a furniture/electronics store. I added a 10" sub a few months later. All together it probably added up to about the same price my friend had paid for his Bose system but I had the luxury of buying piece by piece, paycheck to paycheck.
When my friend came over to check my system out he was floored at the difference in fidelity, how much the speakers filled the room and the quantity of bass. Sure his speakers took up less space in the room, but they were miles away in meeting sound quality of my similarly priced system.
One thing I did notice is that many computer speakers started to follow the same style that the Bose cube speakers used. I had some Cambridge Soundworks speakers that looked very much like a sibling to Bose. They however were a tenth the price.
The Accoustimass speakers are very small and fairly idiot proof in setting up. So if size was your only parameter in buying speakers and you have trouble with anything electronic (ie: setting the time on your digital watch) then Bose is your brand.
Old 10-25-09, 03:04 AM   #25
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
I have still not watched this yet on BD, have seen it but not heard the DTS-HD MA soundtrack yet, think I will give it a whirl tonight
bose, speakers.......
