Home Audio Speakers
Revel vs Paradigm?
Discuss Revel vs Paradigm? in the Manufactured Speakers and Subwoofers forum; Revel vs Paradigm? Thinking about upgrading my speakers for my new HT room... Been auditing some of the brands, such as Dali Lector, ...
Views: 301 - Replies: 25
Old 10-27-09, 02:30 AM   #1
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
  geforce1999 is offline
Revel vs Paradigm?
Thinking about upgrading my speakers for my new HT room... Been auditing some of the brands, such as Dali Lector, Ikon, PSB FCC8, Monitor Audio Silver etc and finally to pick one from the following:
Revel Concerta F12, C12 & S12 for US$3K
Paradigm Studio 100 (with CC690 & ADP590) for US$5K
For Revel, they are good but Paradigm seem to have better spec and sound better... but does Paradigm justified to have another $2k for the package? I don't want to upgrade my speaker set regularly and thinking to have it purchased and last me for another 15 yrs if possible...
Any comment on which one to take? Really need the advice...
Old 10-27-09, 07:20 AM   #2
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Revel vs Paradigm?
Speakers are a lot of personal preference. Personally, I much prefer the Revel Concerta series. I think they're much more neutral and accurate and I know you can push them in a home theater setting without strain.
I have several customers who've used that exact setup along with HSU VTF3 sub(s) and the results have been great.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 10-27-09, 10:11 AM   #3
Alias: lsiberian
Loc: Fort Worth, TX
User: #35637
Since: Mar 2009
  lsiberian is offline
The Revel Concerta series contains the same speakers as the Infinity Beta series they are just rebranded.
so if you can find the beat series speakers for less go for it.
Old 10-27-09, 10:14 AM   #4
Shack Moderator
Alias: Jack
Loc: Sarasota, Florida
User: #40011
Since: Jul 2009
  Jungle Jack is online now
Hello,
The two speaker lines that you are looking at I am quite fond of. I used to own a pair of Paradigm Studio 100's and they are excellent speakers. Revel's are also amazingly well engineered. Revel's Studio Series are some of the finest speakers in the World. Revel on the whole enjoy a very good reputation and in most instances are more expensive than Paradigm's when comparing similar models
In the end it boils down to which you prefer. Usually, people keep speakers for years so do not let the difference in price stop you from getting the one you want.
Cheers,
JJ
Old 10-27-09, 10:26 AM   #5
Alias: lsiberian
Loc: Fort Worth, TX
User: #35637
Since: Mar 2009
From a speaker builder's perspective the Revel drivers are superior to the Paradigm ones. However the build quality of the Paradigm ones tends to be better.
The Revel's are largely limited buy the enclosures which can be improved if you are into modding.
Still I agree with Jungle Jack. Get the best system you can even if you need to wait a while.
Have you examine the B&W lines?
Old 10-27-09, 11:18 AM   #6
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
Thanks for all the comments. I was actually about to go ahead for Revel as the price seems reasonable with decent bulit but then looking at the Paradigm studio 100 let me think, "Will I be regreted if I purchased Revel because by putting a bit more I will have something that I like better?"....
I do like Revel but I love the Studio 100 and CC690 with their dual drivers for mid range I believe Paradigm will produce more than Revel can as Revel is sharing driver for mid and bass... But Paradigm really cost too much.... around 70% more
What should I do !!!
Old 10-27-09, 11:20 AM   #7
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
Nope, I have not tried B&W line, I know they are good for music but I'm 90% in movies and 10% in music...
Old 10-27-09, 11:22 AM   #8
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
bpape wrote: View Post
Bryan
I just bought my SVS PB12+ and it is still sitting in the box waiting for the rest of the speakers (be it Revel or Paradigm) and the new HT room (to be ready in 3 weeks time)
Old 10-27-09, 11:25 AM   #9
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
lsiberian wrote: View Post
Yup, I'm suprise Revel's price is so competitive. It is really a good buy at its price range
Old 10-27-09, 11:26 AM   #10
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
Jungle Jack wrote: View Post
Hello,
Cheers,
JJ
May I ask what do you use now to replace Studio 100? Upgrade huh?
Old 10-27-09, 11:29 AM   #11
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
Actually I don't mind the look of the Revel. I listen to it and I like it. Just wondering if I should spend more now to have something better? To me cc690 and studio 100 are better than F12 & C12...
Old 10-27-09, 12:05 PM   #12
Shack Moderator
Alias: Jack
User: #40011
Since: Jul 2009
geforce1999 wrote: View Post
Hello,
I have over the years usually had both a Home Theater and 2 Channel setup. For my HT 5 years ago, I went with Paradigm Studio 100 V2, Studio CC, Studio ADP V2, and Servo 15. My 2 Channel rig consisted of Martin Logan Aerius i's, Aragon 8008BB, Sony SCD-1, and Conrad Johnson Preamp.
The Version 2 of Paradigm's Studio Series were my personal favorite of the Studio Series. The Studio 100 V2 weighs over 100 pounds whereas the V3 were 20 pounds lighter.
I was so pleased with the Martin Logan's in my 2 Channel setup that I decided to build a Martin Logan HT.
Now, I am using Vantages (Main), Stage (Center Channel), Vista (Surround) and Depth (Subwoofer). I am beyond pleased. I also have a pair of Martin Logan Montages that I swap out with my Vistas to comprise a 2 channel system.
Electrostatic Speakers are not for everyone. They are quite demanding of placement and amplification. Furthermore, compared to conventional speakers, they have a smaller sweet spot. Using a Center Channel helps negate the smaller sweet spot however. All the same I absolutely love Electrostatic Speakers and highly recommend auditioning some if available in your area.
Cheers,
JJ
Old 10-27-09, 09:35 PM   #13
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
JJ, thansk for sharing. Yes, there are so much to learn and there is no perfect system as our requirement is always demand more. Have to enjoy the journey of upgrading.
Old 10-27-09, 09:43 PM   #14
Shack Moderator
Alias: Jack
User: #40011
Since: Jul 2009
Hello,
Geforce, I am pretty sure Martin Logan is available in Malaysia. Might be worth an audition if there is a store which demonstrates them near where you work and live.
I really like the two speaker lines you are considering, but if you have not listened to Electrostatic Speakers, you might be in for a eye and ear opening experience.
Cheers,
JJ
Old 10-27-09, 10:06 PM   #15
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
Thanks for the advice. Will check them out if see the availability.
Old 10-27-09, 10:39 PM   #16
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
Did some research on Electrostatic Speakers and found out that it requires a lot of power to drive the speakers, and also some disadvance on getting the bass, right?
Old 10-27-09, 10:46 PM   #17
Shack Moderator
Alias: Jack
User: #40011
Since: Jul 2009
Hello,
The new generation use ICE Powered amplifiers to drive the woofers on Martin Logan's Vantage, Spire, and Summit X. These are hybrid speakers where only the bass is handled by conventional woofers and the electrostatic panel handles the midbass and treble.
Cheers,
JJ
Old 10-27-09, 10:58 PM   #18
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
Thanks for the info, how about the power handling? Will my electrical bill jump up tremendously, like double?
Old 10-29-09, 03:10 AM   #19
Shack Moderator
Alias: John
recruit's Avatar
Loc: UK - Near London
User: #37302
Since: May 2009
  recruit is online now
good choice in sub Gforce SVS are one of the best sub makers and they produce some serious bass!
Old 10-29-09, 10:04 AM   #20
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
recruit wrote: View Post
Thanks, Recruit. It is more expensive than US MRP but I think it is worth the money for its performance. Just hope that I can the right speakers set to pair with it.
Old 10-29-09, 10:36 AM   #21
Shack Moderator
Alias: John
recruit's Avatar
User: #37302
Since: May 2009
matching different brands of speakers with subs is quite easy, you just need to make sure you get a good calibre of sub and you have, Im sure either the Revel or Paradigm will make you more than happy
Old 10-29-09, 11:03 AM   #22
Shack Moderator
Alias: Jack
User: #40011
Since: Jul 2009
Hello,
The amplifiers in the speakers are actually quite efficient and the new generation of Martin Logan's are relatively efficient. I would not think your power bill would double. The amplifier you use to drive the speakers will have an impact in terms of efficiency.
If you purchase a Class D or any of the other amplifiers which use a switching power supply, your energy usage will be lower than if you use a traditional Class A or A/B amplifier. Regardless of your amplifier choice, I would be surprised if it resulted in your power bill doubling.
Cheers,
JJ
Old 10-30-09, 11:49 PM   #23
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
Hello,
Cheers,
JJ
Noted. Thanks!
Old 11-17-09, 09:56 AM   #24
Alias: Gforce
Loc: Malaysia
User: #43933
Since: Oct 2009
I finally got my speakers last week. Revel F12 for front, Paradigm cc690 for center and Paradigm ADP390 as surround. And I use back my Yamaha for my rear surround. So instead of going for full Revel Concertra or Paradigm Studio, I go partial.
Old 11-17-09, 10:29 AM   #25
Shack Moderator
Alias: Jack
User: #40011
Since: Jul 2009
Hello,
Congrats. The thing about accurate, well designed speakers of a similar design is they should sound good together.
Cheers,
JJ
paradigm?, revel
