| Home Audio Speakers Super High Fidelity Architectural SpeakersDiscuss Super High Fidelity Architectural Speakers in the Manufactured Speakers and Subwoofers forum; Super High Fidelity Architectural Speakers Hi Everyone
I am looking for a pair of speaker for my great room. I will be using them as ... |
Views: 74 - Replies: 5
| Super High Fidelity Architectural Speakers Hi Everyone I am looking for a pair of speaker for my great room. I will be using them as musical listening speakers Size is not an issue, power is not an issue, but they need to be in-wall to please the miss', and I also do not wish to acompany them with a sub-woofer I Love DynAudio, but I dont know if their IP 24 series will be sufficant Cory Welsh McDonald Framing and Renovations Bowmanville (GTA), ON | ||||
| | #2 | ||||
| Re: Super High Fidelity Architectural Speakers Hello, Check out Thiel Speakers. http://www.thielaudio.com/THIEL_Site...int/pwrpt.html They are, to me, the best sounding In Wall Speakers I have ever come across. Cheers, JJ | ||||
| | #3 | ||||
| Re: Super High Fidelity Architectural Speakers Ideally in walls are a big compromise on sound quality. But as we all know "Happy wife happy life" so going with speakers that have a tweeter that can be angled to point at the listening position is a good start as most have fixed tweeters and dont give you very good imaging. Have a look here and see if any suite your needs. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #5 | ||||
| Re: Super High Fidelity Architectural Speakers Ok, size and power are not issues, what about cost? I'll second Kal's recommendation, as long as they fit your budget. Mark | ||||
| | #6 | ||||
| Re: Super High Fidelity Architectural Speakers Hello, Considering he was contemplating Dynaudio and the title of the thread, I figured the OP was after the best. I am really impressed with TRIAD, but think Thiel's Powerpoints deserve an audition as well. Cheers, JJ | ||||
