Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Reliable Hardware: A Reliable Source for Case, Cabinet and Acoustical Hardware! Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Elite Screens offers the finest in affordable projection screens. RAM Electronics: Audio, Video, Home Theater and Computer Cables. Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices ePVision.com: One-Stop place for High-end HDTV, Media hub in the box, Advanced ATSC/QAM/NTSC Tuner Receiver, Network HD Media Player and etc. Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! BOCS - Power Up Your Tivo! Musicians Friend: Your one stop shop for microphones, mic amps and Behringer products. SVSound GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels!
Home Theater Shack Stores Movie Stuff Vendors
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Manufactured Speakers | Subwoofers > Home Audio Speakers
Views: 716 - Replies: 2
Old 11-21-09, 05:46 PM   #1
Matt
  Chester is offline
In Home Stereo Installation (Pictures!)
Here is our IHSS (In Home Stereo System) I know... ceiling speakers suck and typically do not have the best sound; I did not really get to pick the speakers since the people who wired the house basically picked what they always use... I did pick the placement of the speakers in the ceiling. I tinned all of the ends of the wires, picked and setup all of the equipment, and installed all of the rockwool, activated charcoal in the enclosures in the ceilings. Everything has been EQ'd with REW too I also use my ear-EQ system, based on the equal loudness curves at 80 db (ISO 226:2003) as a 'house curve' of sorts... Everything has also been EQ'd using REW on a per-channel basis; so every speaker has its own unique eq, except for in the kitchen where there are 4 speakers (2 in parallel) so they use an average of each channel
The speakers used are MTX H825C's. The amplifier is a Crown CTS-8200 (200 watts/ch @ 8 ohms) with a Crown K1 driving the subwoofers. Everything is EQ'd crossed/over using a Crown USM-810. The USM-810 is driven by a Shure Auxpander 8x8 matrix mixer which can route any input to any channel in the house. The sources are a Numark HDCD1 (sort of like a big ipod with 2 outputs), a Tascam Radio tuner, and an 1/8" jack for an ipod, computer or whatever else you would want to plug in.
Here is a bag of activated charcoal An idea taken from KEF, activated charcoal helps at lower frequencies to increase the apparent size of the box... also the weight hopefully will help deaden some resonances from the gypsum board...
Rockwool (2" thick, cut to 1"thick pieces)
3M Super 74 foaming adhesive is what I have found works best for rockwool
The Backboxx things typically would not be very good however the entire attic area (on the drywall) has been coated with a hard polyurethane foam (vapor barrier) which gives it better stiffness, the barrier is a bit like "Great Stuff" found at hardware stores, but ~1" thick.
The tweeters are adjustable, They are all angled at 15 degrees 'inward' (toward the opposite channel) for uniformity; I used a modified laser pointer which was fixed on top of the dome tweeters to help point the tweeters at the correct point on the floor...
The Kitchen speakers are the "averaged" ones
Comments and feedback welcome
Old 11-22-09, 02:26 AM   #2
Shack Moderator
recruit's Avatar
John
Since: May 2009
UK - Near London
  recruit is online now
Re: In Home Stereo Installation (Pictures!)
Wow! some excellent work there matt, such a tidy install and beautiful place you have
Old 11-22-09, 12:48 PM   #3
Matt
  Chester is offline
Thanks! the kitchen sub needs to be replaced eventually since it is on 10" and does not fill the space well at all (without distortion)
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > Manufactured Speakers | Subwoofers > Home Audio Speakers »
(pictures!), home, installation, stereo
Bookmark and Share
Massage Chairs   Wall Fountains   Bath Vanities   Electric Fireplaces
Dish Network
Search Engine Friendly URLs by vBSEO 3.3.2
