| Home Audio Speakers Large or Small ?Discuss Large or Small ? in the Manufactured Speakers and Subwoofers forum; Large or Small ? My Yamaha RX-V2500 is configured like this :
Front : large
Center : large
Surround : large
Surround back : ... |
Views: 943 - Replies: 18
| Large or Small ? My Yamaha RX-V2500 is configured like this : Front : large Center : large Surround : large Surround back : large Sub : none The bass are send to front My sub is connected with the front via a DCX2496 Is this a good choice for center, surround and surround back ? | ||||
| | #2 | |||||
| Re: LARGE or SMALL ? Quote:
brucek | |||||
| | #3 | |||||
Ampli Yam (used like pre-ampli) --> DCX2496 --> DEQ2496 --> Ampli --> Front |------------------------|------------|--------------------> DEQ2496 --------------> Sub |------------------------|---------------------------------> DEQ2496 --> Ampli --> Centre |------------------------|---------------------------------> DEQ2496 --> Ampli --> Surrounds |--------------------------------------------------------------------------------> Surrounds back This for use my sub in Hi-Fi (mode stereo pure direct on the Yam) Last edited by sonata31; 11-09-06 at 09:48 AM.. | |||||
| | #4 | ||||
| Re: LARGE or SMALL ? I'm not sure I understand your question, but I can comment. You are using a DCX bass management system presumably because you don't like the bass management provided by the Yamaha receiver? The Yamaha is likely a fixed crossover at 90Hz, so it's not hard to imagine why you don't like it. I don't personally see the need for the DEQ with any speaker other than the subwoofer. Equalization on mains, surrounds etc doesn't gain you much. Any equalization for those speakers should be carried out with room treatment. The best the DEQ can do there is add noise. If you're looking for the best possible mains direct pure signal, then don't insert a device like the DEQ into the chain. Its best service would be for the sub alone to remove room resonance. Why not set all your speakers to small except the mains (large) and set the LFE/SUB to Main. That way all bass would be redirected to the main signal, which you then bass manage with the DCX. I would only use the DEQ on the sub... brucek | ||||
| | #5 | |||||||
, it's not a dedicated roomQuote:
Thank You for your response | |||||||
| | #6 | ||||
| Re: LARGE or SMALL ? The advantages of the small setting are that you are not wasting power at frequencies that your mains cannot produce, that phasing problems between the sub and mains are easier to manage, and the crossover region is easier to equalize. If you have enough power on the mains so that you never stretch the amps with low freqs, the speakers can handle deep bass without distortion, and the sub is placed near the mains, it might be ok to avoid the filters in the Yamaha, but rarely are these conditions all met sufficiently that it is advantageous to set to large. Even very good speakers have increased distortion in the mid bass region when trying to produce deep bass that is present in HT program material. Also, brucek, with all due respect, your comments on EQ of the mains assume a lot. Some speakers and installs can definitely benefit from equalization. I agree with your view in most cases, but to make such sweeping generalizations in this field almost always results in wrong conclusions for some systems. I certainly prefer not to have to screw with filters on anything but the subs, but one cannot always use the best speakers, place them in optimal locations, nor treat the room adequately to eliminate the need for some equalization. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #8 | |||||
![]() brucek | |||||
| | #10 | ||||
| Re: LARGE or SMALL ? I probably shouldn't comment as I'll admit that I did get a little lost in the thread.. But, I'd set everything to small if you've got a sub, even the mains. Even if your mains can handle the lower frequencies, cutting off the lower frequencies will put less strain on your speakers and, theoretically of course, make them sound better in the range they do playback. Of course, if after you do that and sound horrible, I'd change it back. JCD | ||||
| | #11 | ||||
| Re: LARGE or SMALL ? Well you could try it both ways (mains set to large and then set to small) and see which sounded best and which gave you the smoothest response in the low end... via REW measurements. REW will tell you which has the smoother response, then see if your ears agree. | ||||
| | #14 | |||||
Am I missing something with that sub-out not being used? Couldn't you simply set that x-over to 200Hz and feed it to the DCX? Maybe I don't understand how the DCX works. | |||||
| | #15 | |||||
| | #16 | |||||
brucek | |||||
| | #17 | |||||
What specifically is "Pure Direct" bypassing to make it "pure"? | |||||
| | #18 | ||||
| Re: LARGE or SMALL ? Also, read this thread about the dramatic improvement of crossing over the mains. You might be better off (or just as well off) not using Pure Direct, but using the sub-out with the DCX and taking the DEQ off the mains. No Pure Direct or added DEQ impurities... pick your poison. | ||||
| | #19 | ||||
| Re: LARGE or SMALL ? Much easier to transport if you move around much... -- Otto | ||||
