Home Audio SpeakersDiscuss Klipsch Reference speakers in the Manufactured Speakers | DIY Subwoofers forum; Klipsch Reference speakers Ok guys have made room to upgrade to the Reference line of Klipsch . Going with the rc-62 center and ... |
Views: 225 - Replies: 22
| Klipsch Reference speakers Ok guys have made room to upgrade to the Reference line of Klipsch . Going with the rc-62 center and rb-51 for fronts and rs-42 for rears . will be using my yamaha 663 AV just wandering if i need to upgrade my rb-51 to the 61 or if the 51s will be fine till i get more cash . And if my receiver will be ok to push these speakers . or do i need to go with an amp for the center ? And if so what amp would be good. | ||||
| | #2 | ||||
| Re: Klipsch Reference speakers Hello, Klipsch's are truly some of the easiest to drive Speakers on the Market. They can play unbelievably loud with very little amplifier power so I really do not think you need to worry about upgrading to an outboard amplifier unless your room is enormous. The RB-51's really should work great with your Center and Surrounds. I really would not be concerned about them being a generation behind. What really matters is you have the same Brand of Speaker for all channels. Cheers, JJ HT Speakers: Martin Logan Vantage (Front), Martin Logan Stage (Center), Martin Logan Vista (Surround), Martin Logan Depth (Subwoofer) Amplification: Parasound HCA-3500, Parasound HCA-2205, Aragon 8008BB AVR/SSP: Onkyo TX-SR875 Electronics: Pioneer BDP-05FD, Pioneer BDP-51FD, OPPO BDP-83, OPPO DV-980H, Sony PS3 60 gb, Denon DVD-3910 Display: Sony KDS-55A3000 | ||||
| | #4 | ||||
| Re: Klipsch Reference speakers Hello, Ideally, all drivers should be the same size, but the huge thing is that all of your Speakers are Horn Loaded. And in truth, having a larger Center Channel is great as it is considered by many to be the most important Speaker in HT. Cheers, JJ HT Speakers: Martin Logan Vantage (Front), Martin Logan Stage (Center), Martin Logan Vista (Surround), Martin Logan Depth (Subwoofer) Amplification: Parasound HCA-3500, Parasound HCA-2205, Aragon 8008BB AVR/SSP: Onkyo TX-SR875 Electronics: Pioneer BDP-05FD, Pioneer BDP-51FD, OPPO BDP-83, OPPO DV-980H, Sony PS3 60 gb, Denon DVD-3910 Display: Sony KDS-55A3000 | ||||
| | #7 | ||||
| Re: Klipsch Reference speakers Hello, Biwiring is a somewhat debated subject. I have never experienced a huge difference biwiring. The true advantage I find to having dual terminals is the ability to biamp which can make a huge difference. Cheers, JJ HT Speakers: Martin Logan Vantage (Front), Martin Logan Stage (Center), Martin Logan Vista (Surround), Martin Logan Depth (Subwoofer) Amplification: Parasound HCA-3500, Parasound HCA-2205, Aragon 8008BB AVR/SSP: Onkyo TX-SR875 Electronics: Pioneer BDP-05FD, Pioneer BDP-51FD, OPPO BDP-83, OPPO DV-980H, Sony PS3 60 gb, Denon DVD-3910 Display: Sony KDS-55A3000 | ||||
| | #9 | ||||
| Re: Klipsch Reference speakers And also Iv been useing the quintet series klipsch and can only turn it up to around -20 be for the neighbors start to beat on the wall lol. So think I'll be fine with the sound lvls Posted via Mobile Device | ||||
| | #10 | ||||
| Re: Klipsch Reference speakers Hello, If your AVR offers biamping, it is almost always for the front channels, (Mains) And in this instance, you can use any Speakers as it does not require 2 sets of Speaker Cable per Channel or Dual Terminals. In most Biamping applications, it is with 2 different outboard Amplifiers. Some choose to use a Tube Amplifier to drive the Tweeter and Midrange Driver and a Solid State Amplifier to drive to Bass driver in a Speaker which offers Dual Terminals. Or 2 Solid State Amplifiers for a super powerful setup. Some Speakers can even be Triamped. These are huge super expensive Speakers on the whole. Cheers, JJ HT Speakers: Martin Logan Vantage (Front), Martin Logan Stage (Center), Martin Logan Vista (Surround), Martin Logan Depth (Subwoofer) Amplification: Parasound HCA-3500, Parasound HCA-2205, Aragon 8008BB AVR/SSP: Onkyo TX-SR875 Electronics: Pioneer BDP-05FD, Pioneer BDP-51FD, OPPO BDP-83, OPPO DV-980H, Sony PS3 60 gb, Denon DVD-3910 Display: Sony KDS-55A3000 | ||||
