How can you reall do that. My sofa is all the way up against the other wall. I have room to put the R50 towers at each corner of the sofa, I even have a little gap space to sneak in maybe an extra P2030 or P2031p as a rear center. But, when the surrounds are so close to your head, can you really properly establish a good surround sound effect?
Also, out of curiosity. The P2030's or P2031's are such a good deal, I was considering setting up the entire room with them.
2 fronts, a center, 2 rears mounted higher above the head on the wall. Maybe even 2 additional fronts that can sit much higher up on the wall unit.
Lastly, if anyone can help. I was worried about the P2031's being 4ohm, and using a Onkyo 807.
I think I read somewhere something about the P2031's ideally having 300W at 4ohm, but the 807 only does 250W at 4 ohm???Sorry, not to good at this stuff.
Should I just stick with the P2030's if that is the case. I certainly don't wanter to undermine the quality of the speaker's output with an insufficient receiver. I plan to probably run 2 subwoofers anyway.
Stick with the 2030p and a separate sub. Less $$, 8ohms, and if you're crossing over at 80hx, you won't miss the low end.
Related Threads
742.3K posts
170.9K members
Since 2006
