Discuss Polk Audio owners thread in the Manufactured Speakers | Subwoofers forum. mazersteven wrote:
I think I'm only going to go with a 5.1 system. The room is real small. 12x11. I ...
I think I'm only going to go with a 5.1 system. The room is real small. 12x11. I purchased 2-LSi9's, LSi7's & LSiC at the same time. I then found a deal on 2-LSi9's and purchased those too. So I'm going to use either 4-LSi9's or use the 2-LSi7's as rears.
No idea on a sub yet.
See it's a small room. Still have to purchase a couch. Seating will only be about 6' from screen.
The screen's bigger when you sit closer, and at 1080, you can sit pretty dang close!
Sure you can go bigger but in smaller room where is the linedrawn and when is it over powering the rest of your system. I like the idea of an IB as mucha s the next nutter on here but if its producing 120-130dB and I have speakers thet only produce 80-85dB you're talkin some serious over powering. That sub I mentioned above will prolly rock a normal sized living (eg; 16' x 12' x 7' to about 20' x 15' x 9') Any room more then that just make a second one and be happy.
You know the saying just because you can, doesn't always mean you should do something..
I just recently picked up a pair of RT3000P's and a CS1000P. In the manual it say you can run a "Line In" to the sub amp from a pre-out of your processor and a "High Level" from your processor to the mids-highs. My question is, has anyone done this (pre outs from Left and Right channels and high level for mids-tweets) and is there any benefit in sound by using this method? I have a Denon 3803 so I have the capability to do this but before buying more sub cables I wanted to see if it would be worth it. Thanks.
Thanks Mike. I am an active member over at the Polk Forum (Midnite Mick) and am curious to here some of the older Polk's. Would like to know the what the old SDA's sound like. I have a feeling they would be right in my wheelhouse in regards to my preferences. I love a big 3 dimensional sound and if they sound open as well........well .
Mike
I'll bite, I have a pair of Polks SRS SDA2's dating to circa 1985.... They have been retired from my 2nd system and are now on duty as fronts in a 5.1 system at a second home I own with my brothers. They still sound quite good, but always needed a little "junk in the trunk"...we gave it to them with a little bit of help from a "semi-retired" Hsu 10v sub. Very non-fatiguing sound and ability to play quite loud, but just a bit of a veil in the upper midrange relative to newer, far more expensive boxes. Couldn't bear to part with them.
I have two 5.1 home theater setups with mostly Polks!
The living-room setup consists of:
Mains: RTi100's
Center: CSi30
Rear: RTi38's
Sub: HSU STF-2
Everything is powered by an Onkyo TX-SR702 Receiver, video and music comes from a Denon DVD-2910. A Samsung 56" DLP Set (HL-P5663) completes the setup.
Everything is driven by an old and cheesy Pioneer receiver (VSX-D509S). Video comes from a Toshiba HD-A3! which drives a 42" Olevia LCD monitor (342i).
