Mirage speakers - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Home Audio Speakers
Mirage speakers
Discuss Mirage speakers in the Manufactured Speakers and Subwoofers forum; Mirage speakers Anyone here have any experience with the older Mirage speakers? I have a pair of M5si's that appear to have ...
Old 01-24-07, 05:57 PM   #1 (Link)
Alias: Karl_in_Chicago
Loc: Chicago
User: #5280
Since: Jan 2007
  Karl_in_Chicago is offline
Mirage speakers
Anyone here have any experience with the older Mirage speakers? I have a pair of M5si's that appear to have a blown driver and it isn't immediately apparent how to get "behind the cloth" to access the speaker's guts. I don't want to go yanking stuff off and *assume* it was supposed to come off and then find out I was wrong. After looking at them for a while I'm guessing that maybe I remove the top end cap and then I can manipulate the cloth sock but I don't want to force anything and further damage the speaker.
Old 01-24-07, 07:42 PM   #2 (Link)
Alias: Thebake
User: #275
  srbaker is offline
Re: Mirage speakers
I had an old Pair of M7si's. Replaced the tweets after the kids poked them in. Just gently pry the top off. I think I used a couple of butter knifes. You can then slip the sox off. After that driver replacement was not that hard. I gave the speakers to my sister, but I liked them so much for my HT I my be an indian giver. (not so bad since she is not even using them, but I will need to find a center. Hope this helps.
Rich
Linux Slimserver, serving up FLAC to SqueezeBox3, Linear power supply ->
Theta Data II ->
MSB Digital Director -> MSB Gold Link III, Monolithic HC-2b Power supply ->
Rega P3 (On a Target wall rack), Rega Exact -> Adcom GFP - 710 ->
Manley Stingray -> Klischorns or Reference 3A Laveritas
Old 01-24-07, 11:22 PM   #3 (Link)
Loc: Chicago
User: #5280
Since: Jan 2007
Re: Mirage speakers
That helps a lot, Rich, thank you! I figured it was done as you describe but I wanted to get confirmation from somebody that had actually done it first before I started potentially tearing them apart. I'll still need some kind of response from Mirage to see about a replacement driver once I identify what's wrong but now at least I can get started. Thanks again.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
