| Home Audio Speakers speaker comparissonDiscuss speaker comparisson in the Manufactured Speakers and Subwoofers forum; speaker comparisson Which speakers would produce the best sound quality (ignoring all other factors such as size, price etc.)
1. The KEF ... |
Views: 1050 - Replies: 3
| speaker comparisson Which speakers would produce the best sound quality (ignoring all other factors such as size, price etc.) 1. The KEF KHT-3005 http://www.kef.com/ht3000/index.htm or 2. PSB Image Concert Theater System http://www.psbspeakers.com/imageHTS....43b9510ba0145c thanks for all help | ||||
| | #3 | ||||
| Re: speaker comparisson I'll throw in the following: Audio Nirvana is in the ear of the beholder. All I mean by this is that you should take a listen to both speakers yourself to determine which one you like better. What may one person may like, you may hate. You might wanna take a look at this while audtioning speakers. That being said, and like Nova, I haven't listened to either speaker either, I would have to say the PSB's would probably sound better. All things being equal, size does matter. JCD | ||||
| | #4 | ||||
| Re: speaker comparisson voumv, is there any way you can audition these 2 speakers in your home? Unfortunately, I haven't heard them either. I know that the KEF's have the tweeter in the center of the mid-range driver. This can help with time coherence-that sounds from either speaker will reach your ears correctly timed. They also have a much higher high freq. response, which some say can present more realism (that would depend on the recording itself, i.e. did the mic used in the initial recording have that kind of high freq. response?).The PSB's will probably have a lower extension on the bass. The only thing I can add is that other KEF's I have heard have sounded slightly shrill to me (of course, my personal opinion). I don't think you will be dissapointed with either choice. Remember what your ears hear is the final authority. Have fun, Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
