Home Audio Speakers
Which to sell
Discuss Which to sell in the Manufactured Speakers and Subwoofers forum; Which to sell Which speakers are better out of the two? The JBL HLS410 or the JBL Control 1Xtreme? I currently have both ...
Views: 1071 - Replies: 7
Old 02-26-07, 11:55 AM   #1
b567932
Inactive
Alias:
User: #
Posts: n/a
Question Which to sell
Which speakers are better out of the two? The JBL HLS410 or the JBL Control 1Xtreme? I currently have both of them and I' am trying to decide which one to sell on E-bay. I will need to sell one of them but I don't know which I should sell. I need to save money to get better speakers but in the mean while I need to get the most I can and I sure don't need two pairs of speakers so please tell me which speakers is the best out of the two so I can sell one. Both are in good condition and sound like new.
Here are some specs on the JBL Control 1Xtreme.
CONTROL1XTREME
2-Way, 4-Inch (100mm), Personal-Size Monitor Loudspeaker
Small-footprint, personal-size monitor with rugged, molded enclosure brings the music anywhere it's needed, including the home or office.
Shielded components allow placement next to video monitors.
Optional wall-mount brackets available (WBC1).
MSRP: $199.99PR
SPECIFICATIONS
General
Recommended Power Amplifier Range 10 Watts – 80 Watts
Impedance 8 Ohms
Sensitivity (2.83V @ 1m) 89dB
Frequency Response 80Hz – 20kHz
High-Frequency Driver 1/2" Titanium-laminate dome, shielded
Low-Frequency Driver 4", Shielded
Dimensions
(H x W x D) 9" x 6-1/16" x 5-7/16"
(228mm x 155mm 139mm)
Weight 5.2 lb (2.4kg)
Here's some specs on the JBL HLS410.
HLS410
Video Shielding allows speakers to be safely placed near a TV without distorting your television's picture.
MSRP: $229.00PR
SPECIFICATIONS
First Manufactured 1998
Last Manufactured 1999
First MSRP $229.00
General
Sensitivity (2.83V @ 1m) 86
Impedance 8
4"
Midrange Driver N/A
High-Frequency Driver 10mm mounted in Constant Directivity Horn
Recommended Power Amplifier Range 15 - 100 watts
Dimensions (H x W x D) 10 x 5 1/2 x 6 1/8"
Frequency Response (±3dB) 75 - 20kHz
Old 02-26-07, 11:56 AM   #2
b567932
Inactive
Alias:
User: #
Posts: n/a
Re: Which to sell
I want to know the general feedbacks of the two speakers. Example: Someone might say the JBL HLS410 is a better speaker since it uses a horn and it can have a lower crossover point to blend the music better and the woofers is better quality and materal then the Control 1Xtreme. By the way that part where I said having lower crossover point is true fact about the HLS410.
Old 02-26-07, 12:10 PM   #3
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: Which to sell
Well, have you listened to both? How do you like the sound of them?
-- Otto
Old 02-26-07, 01:00 PM   #4
b567932
Inactive
Alias:
User: #
Posts: n/a
Re: Which to sell
Yes I currently own both pairs and I need peoples feedback on what they think about the two. I want to see which speaker is rated the best out of the two from peoples feedback.
Old 02-26-07, 01:14 PM   #5
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
Re: Which to sell
If you are going for the most money, I would tend to think that the horns would be more impressive to a prospective buyer on ebay. A lot depends on how you are going to use the remaining pair and what you are looking at to purchase. Sorry, I haven't heard either. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 02-26-07, 05:25 PM   #6
Alias: terry
Loc: bathurst nsw australia
User: #1819
  terry j is offline
Re: Which to sell
list them both, pull the one that is left after the first is sold???? I don't really know how ebay works so maybe that is not feasible....
Old 02-26-07, 08:35 PM   #7
Alias: Jay
jackfish's Avatar
Loc: Western Wisconsin
User: #5100
Since: Dec 2006
  jackfish is offline
Re: Which to sell
b567932 wrote: View Post
Who cares which is "rated better"? Keep the ones that sound the best to you.
Old 03-03-07, 06:07 PM   #8
b567932
Inactive
Alias:
User: #
Posts: n/a
Re: Which to sell
I have decided to keep the Control 1Xtremes and I removed the Titanium-Laminated dome tweeters and I ordered two Polycarbonated dome tweeters that was used in the orginal Control 1 since I like the sound of Polycarbonate better then titanium-laminate.
Both the Control 1Xtreme and the orginal Control 1 uses same size woofers and tweeters. I did learn one thing for sure is that the woofers model number is exactly same as the pro Control 1. Only the tweeters said Control 1X. So I just swap the Titanium-Laminate tweeters to Polycarbonate tweeters that are used in the orginal Control 1 and it sounds perfect as I want meaning it sounds exactly like the Orginal Control 1 from Pro even the power is the same, bass and highs same etc.
