Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Manufactured Speakers | DIY Subwoofers > Home Audio Speakers
Home Audio Speakers
  Discuss I need help setting the crossover in my new receiver in the Manufactured Speakers | DIY Subwoofers forum; I need help setting the crossover in my new receiver Hello to all..this is my first post and I know it will sound very ignorant. My set up is as ...
Views: 1303 - Replies: 3
Old 03-25-07, 11:27 AM   #1
johnwestcoast
Inactive
Alias:
User: #
Posts: n/a
My set up is as follows:
HK AVR-335 that has four crossover settings: 1 for mains, 1 for center, 1 for sub, 1 for surrounds.
My fronts are Infinity RS 525s: The frequency response is 52Hz-25KHz +/- 3 db
The crossover frequency is 2800 KHz (I don't know what that means).
My center is a Klipsch KG 2.2V with a frequency response of 50Hz-20kHz±3dB
My sub is a JBL DS-10...not sure what the specs on this are.
My surrounds are Cerwin Vega L-7s...again, not sure of the specs.
The factory crossover settings from my receiver are 100Hz for all 4 speakers. I would like to send more low end frequency to the sub as to not distress the fronts (mains).
Any advice would be great.
Thank you in advance.
Old 03-25-07, 02:13 PM   #2
Shack Moderator
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: I need help setting the crossover in my new receiver
Welcome to the Forum, John!
I don’t think you really have a problem at all. A crossover setting of 100 Hz between the mains and sub will work great with even the smallest main speakers.
Old 03-25-07, 04:10 PM   #3
Platinum Member
Alias: Darren
Darren's Avatar
Loc: Washington
User: #43
  Darren is offline
I prefer an 80Hz crossover or slightly lower. 100Hz is too high for my taste.
Old 03-25-07, 10:13 PM   #4
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Hello John and welcome to the Shack!
johnwestcoast wrote: View Post
2800KHz is the crossover point in your 525's between the woofer and the tweeter. In your case it's not a spec that will mean a lot to you as far as setting your receiver crossover points.
The general rule is 80Hz for most setups, although 100Hz will work. You might try both and see which you like.
For the mains, center and surrounds, the receiver is going to direct all frequencies above 80Hz or 100Hz, whichever you choose, to the appropriate speaker and anything below that will be sent to the sub. Those are considered "high pass" crossovers. Make sure you set the sub crossover the same as the mains. The sub crossover is a "low pass" crossover and all the lows below its crossover setting will be sent to it. Not knowing the specs on the surrounds you might set them at 100Hz, until you find out what their frequency response is. You can always test them, if they seem strained, turn the crossover up.
« Home Theater Shack > Manufactured Speakers | DIY Subwoofers > Home Audio Speakers »
Bookmark and Share
Dish Network
