Home Audio Speakers
Input on new setup
Discuss Input on new setup in the Manufactured Speakers and Subwoofers forum; Input on new setup Hi this will be my first home theater setup ever. I have been doing some research and some lurking around ...
Views: 693 - Replies: 8
Old 04-12-07, 12:58 PM   #1
Fezzy
Inactive
Alias:
User: #
Posts: n/a
Input on new setup
Hi this will be my first home theater setup ever. I have been doing some research and some lurking around the forums. I have somewhat of a tight budget (1,500.00) I originally wanted a 5.1 setup but the right price came by and I now own a Yamaha 5960.
From what I been reading, I have deiced to go with a VTF-2 MK 3 sub. I really want a set of floor standers and been looking in to the Polk speakers. Any particular model that I should look into.
The surround speakers I really don’t know what to look for. I see that a few recommend the SVS speakers. They seem good but a bit bulky.
Oh I have a fairly large room it is about 25x18.
Any help would be greatly appreciated.
Old 04-12-07, 02:12 PM   #2
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
Re: Input on new setup
HI Fezzy, welcome to the Shack. I have owned several speaker sets and since I now own all SVS, I can assure you that they are great speakers. You will have to make the final determination based on your budget and preferences. You should consider some type of room sound treatment and be sure to download and use the RoomEQ Wizard. Have fun, and keep us posted. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 04-12-07, 06:36 PM   #3
Alias: Jay
jackfish's Avatar
Loc: Western Wisconsin
User: #5100
Since: Dec 2006
  jackfish is offline
One can still find the Infinity Primus 360 for $375/pair. The Infinity Primus 150 and C25 are still around as well.
Old 04-13-07, 09:44 AM   #4
Fezzy
Inactive
Alias:
User: #
Posts: n/a
jackfish wrote: View Post
Wow that is one of the speakers I was looking at. Would you mind sharing were you found them?
Also what do does everyone think of the Infinity Primus 362?
Old 04-13-07, 09:52 AM   #5
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is offline
Welcome to the Shack.
How much of that $1500 budget is left?
And, Wow,... by bulky do you mean the SVS speakers are too big,.....????
Mark
Old 04-13-07, 10:39 AM   #6
Fezzy
Inactive
Alias:
User: #
Posts: n/a
nova wrote: View Post
Thanks for the welcome. The 1500.00 is dedicated to the speakers and sub. Since the sub is on its way, I now have about 1,000.00.
I wanted to use the SVS speakers as the surround speakers. I have never seem them in person. Only took measurements and tried to make a paper model.
Also, Do I really need the 4 back speakers. Is it ok to just start with a 5.1 setup and add the two speakers later?
Thanks for all your help.
Old 04-13-07, 10:56 AM   #7
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
You can do quite well with $1000.
If you like the Infinity Primus speakers... you can get a good deal on those via the Shack Shopping Mall. You might even be able to squeeze in a pair of Polk Monitor 70's with a matching center and surrounds.
Another option would be the Boston Acoustics ... probably the VR1's, with the VRC center and VRX surrounds.
But don't shrug off the SVS SBS-01 system, even though you'd need stands. With you room you might want to step up to three SCS-01's across the front. Here's a thread on those.
I'd say you could easily start out with a 5.1 system, but with that size room you may eventually want to consider 7.1.
Old 04-13-07, 01:50 PM   #8
Alias: Jay
jackfish's Avatar
User: #5100
Since: Dec 2006
  jackfish is offline
There you go, the new Infinity Primus P362 for $300 a pair at the Electronics Expo through the Shack Shopping Mall. What a deal on a very good speaker!
Now that I know the Shack Shopping Mall is such a great place I have to price the P162s, PC350 and PS212!
Old 04-16-07, 12:08 PM   #9
Alias: Bob
khellandros66's Avatar
Loc: Pittsburgh, PA
User: #962
Since: Jun 2006
  khellandros66 is offline
Also take alook into the AV123 X-Series the new towers should be out soon if not shipping pre-orders already.
I also second the Polk M70s + matching center and rears. For a Sub go DIY its easier then most think and much more return for your money.
~Bobby
