| Home Audio Speakers Opinions on portable MP3 player speakersDiscuss Opinions on portable MP3 player speakers in the Manufactured Speakers and Subwoofers forum; Opinions on portable MP3 player speakers My folks want some speakers they can plug into their MP3 player to take on travel and while boating. I ... |
Views: 667 - Replies: 3
| Opinions on portable MP3 player speakers My folks want some speakers they can plug into their MP3 player to take on travel and while boating. I can't tell much difference between all the different offerings out there. Does anyone have any that are especially worthwhile? Otherwise I may just find them a cheap one on sale. | ||||
| | #2 | ||||
| Re: Opinions on portable MP3 player speakers Tough call there, Boom. My best suggestion is to find one or two stores that sell them and buy a few of the ones that appear to be the best. Take them home and audition them, and return the “losers” for a refund. Kind of a pain, I know, but it’s probably the best way to evaluate and choose the best one – if you’re interested in sound quality, that is. Of course, your folks might have other priorities – like ease of use, portability, etc. Regards, Wayne | ||||
| | #3 | ||||
| Re: Opinions on portable MP3 player speakers Hi, I would suggest you to visit minispeakers site, there you will find good options for choice at reasonable price. I had a pair of mp3 speakers from there, which has a great sound quality, simple, and portable. Try once and see..., ![]() | ||||
| | #4 | ||||
| Re: Opinions on portable MP3 player speakers Logetich mm28 is a nice speaker based of the NXT flat speaker design. Designed around being portable with pretty nice sound quality can be had online for $20 if you can find them. Check reviews for specs/design to see if it's what you're looking for. Logitech doesn't still actually make them anymore which is sad. I've had mine for quite a while and have put it through serious abuse. Takes 4 AA's (I use rechargeables) which last 40-50 hours (3-4 days of constant use) | ||||
