Home Audio Speakers
speaker selection
Discuss speaker selection in the Manufactured Speakers and Subwoofers forum; speaker selection I will be picking up a 28 foot Travel Trailer this weekend & would like to put in a nice ...
Views: 693 - Replies: 5
Old 04-25-07, 10:46 AM   #1
Alias: john
User: #7420
Since: Mar 2007
  mirage1 is offline
speaker selection
I will be picking up a 28 foot Travel Trailer this weekend & would like to put in a nice 5.1 system in Do not want to go with a H T I A BOX & really do not care for Bose that much So what would you all pick that would sound nice
Old 04-25-07, 10:59 AM   #2
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
Re: speaker selection
John, it depends on your budget. There are a few fairly good HTB's out there, but, if you can spend a little more you should be able to find a great, however small, bookshelf system with a good sub. Let us know. If you could afford a Bose, you can find a much better system at that price level. Have fun, Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 04-25-07, 12:42 PM   #3
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
The other question I'd ask is how big can they be? Can they be the size of the SVS system? Or would it need to be smaller? If the speakers themselves are fine, but the sub is too big, you can buy the 5.0 system and then get a sub from AV123. The SVS sub is going to be "better", but that little sub from AV123 was amazing for it's very petite size.
There are several systems out there that I'd recommend, but I'd wanna know how much and how big.
JCD
Old 04-25-07, 05:02 PM   #4
Alias: john
User: #7420
Since: Mar 2007
  mirage1 is offline
The SVS system looks about the right size maybe a little smaller if possible budget + or - $1500.00
Old 04-25-07, 06:59 PM   #5
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
User: #53
  JCD is offline
I'm partial to Paradigm.. you might want to check out their Cinema line. They're smaller than the SVS's. Just a TAD smaller than the SVS's would be the Atom's.
I think any of the above would be a great bang for the buck.
It any of these scenerio's, I'd still go with that AV123 sub -- size is going to be an issue and I was VERY impressed with it's performance when I had a listen a while ago.
JCD
Old 04-26-07, 08:45 AM   #6
Alias: john
User: #7420
Since: Mar 2007
  mirage1 is offline
Thanks for the help I will go check out the Paradigm line next week
