Home Audio Speakers
Do you use shorting bars?
Discuss Do you use shorting bars? in the Manufactured Speakers and Subwoofers forum; Do you use shorting bars? I do not have the shorting bars for one of my e60s Is it better to just cut short cable ...
Views: 658 - Replies: 1
Old 05-10-07, 12:52 PM   #1
Alias: jwhite
Loc: Houston,Texas
User: #6296
  jwhite8086 is offline
Is it better to just cut short cable to jump the biampable speaker terminals together, also should I connect to the top or bottom terminals first?
Old 05-10-07, 12:56 PM   #2
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: Do you use shorting bars?
jwhite8086 wrote: View Post
I've used them when they came with the speakers. If I were to lose them, I would just use a short piece of wire, as you suggest. The end result should be identical, assuming you are using thick enough cable. I use 12 gauge all the way around, and that's probably overkill, especially for a short run of 2" or so.
Connecting the bottom or top terminal will make no difference electrically. Just wire it all up and you should be fine.
Good luck!
-- Otto
