| Home Audio Speakers center channel vs studio monitors?Discuss center channel vs studio monitors? in the Manufactured Speakers and Subwoofers forum; center channel vs studio monitors? Hello everyone.....Was wondering if i use studio monitors for center channel would that be ok? Or is that kinda stupid? ... |
Views: 634 - Replies: 4
| center channel vs studio monitors? Hello everyone.....Was wondering if i use studio monitors for center channel would that be ok? Or is that kinda stupid? I was/or thinking of useing def tech 350 for center channel(s).... thanks | ||||
| | #2 | ||||
| Re: center channel vs studio monitors? Hey mike, In general, a monitor is fine for a center channel. The important thing is that it matches to other speakers in the system, especially the left and right speakers. When the front three speakers match, it provides a much more cohesive soundstage as things pass across the front. And when I say "match" I don't necessarily mean that they have to be identical to the L/R speakers, but they should be from the same "family" of speakers. Most manufacturers provide a series of speakers for L/C/R that kind of "go together." That said, if the center is indeed the exact same speaker as the L/R, well, then, you have an even better match. If you are planning on using the DT with some other manufacturer's speakers on the L/R, it will work, but the soundstaging won't sound the best. It would get you by for a while, though... Good luck. -- Otto | ||||
| | #3 | ||||
| Re: center channel vs studio monitors? Mike, that would be fine. The best setups have all 3 front speakers using the same brand/model. That way you have timbre matching across the front. Make sure you level match carefully. Speaker placement and room treatment are also beneficial to the overall sound quality. With my SVS SB-01/Plus/2 setup, I think my sound is better than the local theaters! Have fun, and welcome to the Shack. Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #5 | ||||
| Re: center channel vs studio monitors? I have to admit I’m kinda leery of a home audio branding calling their speaker a “studio monitor” – i.e., a smallish, rugged speaker designed for continuous output at high levels. Not that matters much for home use if it really is just a glorified home speaker, but the other hallmark of a studio monitor - being designed for nearfield use - may make a difference. Since speakers will naturally sound brighter the closer you are to them, a true studio monitor - typically listened to at distances of only a few feet - will be voiced accordingly. I.e., with the highs attenuated so that they sound natural and balanced at close range. Put a true studio monitor in a home theater situation, where listening distances are typically 10-12 ft. or further, they may sound a bit “soft” at the upper frequencies. As such, you may need to tweak the treble control a bit to compensate. Of course, if the Def Tech 350 is not a “real” studio monitor, but just a fancy name given to a regular home speaker, none of the above will apply. ![]() Regards, Wayne | ||||
