Home Audio Speakers
Martin Logan nuts
Discuss Martin Logan nuts in the Manufactured Speakers and Subwoofers forum; Martin Logan nuts How many other Martin Logan guys are on here? Just wondering and if so what are you running? Heres my ...
Views: 3545 - Replies: 33
Old 08-08-07, 12:42 AM   #1
Alias: Kurt
kurt's Avatar
Loc: Minneapolis, MN
User: #10606
Since: Aug 2007
  kurt is offline
Martin Logan nuts
Heres my list-
Martin Logan Summits (fronts)
Martin Logan Stage (center)
Martin Logan Vistas (rears)
Old 08-27-07, 12:42 PM   #2
Alias: Pete
User: #360
  phogandive is offline
Re: Martin Logan nuts
Hi,
I'm running ML CLS's for front R+L, with 12" DIY woofers acting as stands for them, and an ML Theater for the center. Also have an 18" Velodyne for a sub, and using cheapie RS speakers for rears.
Peter
Old 08-27-07, 01:02 PM   #3
TheChefO
Inactive
Alias:
User: #
Posts: n/a
I've got a pair of Scripts, but they don't fit my current layout (no room on either side of the screen).
Great sound though when paired with a proper sub!
I've had to step down to three HSU centers that sit under the screen... not ... quite ... the same.
Old 10-18-07, 04:52 PM   #4
Alias: Looney
Loc: Topeka, KS
User: #2678
Since: Sep 2006
  looneybomber is offline
I don't own any, but I do drive by their production plant every once in a while. I really should stop in and take a tour...
Old 10-18-07, 04:57 PM   #5
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
I really wish I could afford these... but it's only a dream for me.
Old 10-21-07, 01:12 AM   #6
Motegi
Inactive
Alias:
User: #
Posts: n/a
My local Magnolia store was clearing out their existing MartinLogan stock a few months ago and I JUST missed out on a set! I've been kicking myself ever since
Old 11-01-07, 02:07 AM   #7
Owner
  Sonnie is offline
I finally joined the club...
New thread here!
Old 11-21-07, 12:00 AM   #8
Alias: daniel
Loc: Varennes, Québec
User: #5208
Since: Dec 2006
  daniel is offline
I'm going to buy Martin Logan Vantage next spring. If I had more money I would buy the Summit but I would be surprised if I have that kind of money.
Unless I find a used pair.
Old 11-21-07, 12:35 AM   #9
Owner
  Sonnie is offline
Check Audiogon... I know there were some Summits there and Vantages as well at a very good price.
Old 11-21-07, 12:47 AM   #10
Alias: Jerome
jerome's Avatar
Loc: Norway
User: #8468
Since: Apr 2007
  jerome is offline
I've got a pair of Vista as front speakers. The rest of my current setup is described in my signature.
And yes, I love them !
Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha
Old 11-21-07, 12:59 AM   #11
Owner
  Sonnie is offline
My Motif center will be in tomorrow...
Old 11-21-07, 10:07 AM   #12
Alias: Rodny
Rodny Alvarez's Avatar
Loc: Millbrook AL
User: #158
  Rodny Alvarez is offline
Sonnie!!
How about some pics!!
Old 11-21-07, 10:44 AM   #13
Owner
  Sonnie is offline
Patience... I've got to go to Troy to pick up the speaker first. I also have a pair of PC-Ultra's coming in as well.
Old 11-21-07, 10:54 AM   #14
Alias: Rodny
Loc: Millbrook AL
User: #158
PC ULTRAS!! WHAT!!!!!!!!!!!!!!
You don't need any more speakers
Old 11-21-07, 05:06 PM   #15
Owner
  Sonnie is offline
I know... I've got all I want now.... I promise, I'm not going to buy anymore.
Okay... maybe some ML Fresco surrounds if I can ever find a deal on a discontinued or used pair in black.
Old 11-22-07, 02:04 PM   #16
kioko12
Inactive
Alias:
User: #
Posts: n/a
To those who own ML's, how much power are you running per channel? I've heard that they require a lot of power to sound good. Is this true? Can they be run using a receiver, or do you need a dedicated big-dollar amp?
Old 11-22-07, 03:48 PM   #17
Alias: Jerome
jerome's Avatar
Loc: Norway
User: #8468
Since: Apr 2007
  jerome is offline
The main problem with ML speakers is not that they need a lot of power to sound good but that they have very low impedances at high frequencies (1.2Ohms at 20KHz for Vista for instance).
This puts some constraints/restrictions on the amplifier. Not all amplifiers can deal with very low impedances (Bryston have problems) and most of the receivers fail to do so too. If you go for ML without build-in amplifiers for the panels then you will need a separate amplifier which is happy at driving very impedances.
Of course it helps to have a powerful amplifier (to get tight bass) but my Arcam P1000 with 125W per channel is more than I need.
For info: bi-amping do not help on ML (been there ... )
Old 11-22-07, 03:58 PM   #18
Owner
  Sonnie is offline
My Anthem MCA-50 runs 180wpc/8ohms ... 265wpc/4ohms ... 340wpc/2ohms ... that's with all 5 channels driven.
The Denon 2807 I was using previously did well until I really cranked it up loud, then it became harsh. The Anthem stays very smooth throughout the volume range. For movies the Denon seemed fine, but the music concerts is where I noticed it seemed like it was running out of gas.
Old 01-11-09, 11:40 AM   #19
New Member
Alias: Ron
Loc: Los Angeles, CA
User: #13105
Since: Nov 2007
  Turbo Ron is offline
I have the Martin Logan Summits front right and left, and using a McIntosh 402 amp, 400wpc. Center speaker Martin Logan Stage, and Martin Logan Motif surrounds using a McIntosh 205, 200wpc to power the center and surrounds speakers.
Old 01-11-09, 05:27 PM   #20
Alias: daniel
User: #5208
Since: Dec 2006
  daniel is offline
I have Martin Logan Vantage loudspeaker. Driving them is a "big" Simaudio 50w/ch 8 ohms (it double for 4, than 2. Minimum recommended impedance: 1 ohm. ( maximum remembered power tested :540w)
They sound huge and I don't need that many watts to get High spl.
I would like eventually to try tube amp. ( I've found that most sounded and looked gorgeous)
Old 01-13-09, 01:21 AM   #21
Owner
  Sonnie is offline
In my next dedicated HT room... I will have nothing my ML speakers...
I truly miss mine.
Old 01-14-09, 09:08 PM   #22
New Member
Alias: Brian
Brian_74's Avatar
Loc: Tucson, AZ
User: #31748
Since: Jan 2009
  Brian_74 is offline
I have ML Vantage and will soon *hopefully* have a Motif center. I'm driving them with a Sunfire TGA5200, 200WPC. Mmmm Good
Old 01-23-09, 07:44 PM   #23
Owner
  Sonnie is offline
I am leaning heavily towards the Vantages right now.
Old 03-08-09, 11:43 AM   #24
Alias: Rodny
Loc: Millbrook AL
User: #158
Well I just purchase a pair of Aeon i from audiogon, I listened to some Donal Fagen last night for a little bit and the sound, imaging and stage its unbelivalbe, I still need to adjust them a little bit more, cant wait to get the center channel
Name:  DSCN0015 (Copy).JPG
Name:  DSCN0020 (Copy).JPG
Name:  DSCN0027 (Copy).JPG
Name:  DSCN0017 (Copy) [640x480].JPG
Old 03-08-09, 09:43 PM   #25
Owner
  Sonnie is offline
Nice... and welcome to the club...
I ended up going with the Spire's, Matinee and Clarity's. I am excited about getting the HT room ready so I can enjoy these things.
