Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Reliable Hardware: A Reliable Source for Case, Cabinet and Acoustical Hardware! Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! RAM Electronics: Audio, Video, Home Theater and Computer Cables. PacParts: Replacement parts & accessories from the most recognized manufacturers in the Consumer Electronics Industry! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices Fi Audio: Infinitely amazing balanced high end musicality designed drivers! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! BOCS - Power Up Your Tivo! Elite Screens offers the finest in affordable projection screens. Musicians Friend: Your one stop shop for microphones, mic amps and Behringer products. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels!
Go Back   Home Theater Forum - Home Theater Systems - HomeTheaterShack.com > Manufactured Speakers | DIY Subwoofers > Home Audio Speakers
Home Audio Speakers
Multiple HT Speakers  Discuss Multiple HT Speakers in the Manufactured Speakers | DIY Subwoofers forum; Multiple HT Speakers Hi .. I have 30 - 6 1/2" 4 ohm FR (misnomer) speakers for 5.1 HT. I am going to ...
Views: 1039 - Replies: 19
Old 08-11-07, 02:12 AM   #1
Alias: Zene
User: #5600
Since: Jan 2007
  Zene is offline
I am going to try to use as many as impedances will allow.
I've asked this before but forgot answers and maybe newer thinking will help.
All three fronts will be equal amounts, but would like to know
proportions of rear surround quantities to aim for. The less I need, say 2 each in rears vs. 4 for fronts the more can go up front.
Anyone care to comment? If not I can live with my 1980's RS speakers.
Zene
Old 08-11-07, 09:43 AM   #2
Shack Moderator
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: Multiple HT Speakers
Love to Zene, but I didn’t understand any of that. Are you asking if you can use say, ten speakers for surround sound instead of the usual five or so?
Old 08-11-07, 10:26 AM   #3
Alias: Jay
jackfish's Avatar
Loc: Western Wisconsin
User: #5100
Since: Dec 2006
  jackfish is offline
If you wire speakers in parallel you end up with half the impedence value, wire them in series and you double the impedence. The math is pretty simple even with multiples of speakers. Most HT amps should be run at 6 or 8 ohms, most do not like a load 4 ohms or lower. I'd shoot for 8 ohms for any given channel. Also, I think 4 for the rears, 6 for the center and 8 for the fronts would work.
So if you wire two 4 ohm speakers in series it will yield 8 ohms. If you take two speakers so wired and run them in series with another two so wired it will yield 16 ohms, in parallel it would be 4 ohms.
This explains it, including series/parallel wiring.
http://www.termpro.com/articles/spkrz.html
Stacking many speakers together could result in phase problems.
Old 08-11-07, 04:17 PM   #4
Alias: Zene
User: #5600
Since: Jan 2007
  Zene is offline
Thanks Jay ... Wiring is no problem but did see that 5 would yield 8 ohms with one in series. Never encountered that before. Is it acceptable to do that or do they have to be even quantity clusters, 2,3,4 etc.?
Also, why less for center channel, thought they should be same as fronts?
Plan to curve the arrays to help eliminate notch problems. Will that change your opinion on quantity per channel?
Zene
Old 08-11-07, 08:20 PM   #5
Alias: Jay
jackfish's Avatar
User: #5100
Since: Dec 2006
  jackfish is offline
They can be any multiple as long as the end result of parallel/series combinations is a 6 to 8 ohm load on the amplifier. The center channel should complement the front speakers, so that array could be equal to that of each front but doesn't have to.
Old 08-12-07, 05:30 PM   #6
Alias: Zene
User: #5600
Since: Jan 2007
  Zene is offline
Didn't come close to answering my question, but thanks for the input. Probably my inability to explain my question. Did learn though.
Zene
Old 08-13-07, 09:41 AM   #7
Alias: Jay
jackfish's Avatar
User: #5100
Since: Dec 2006
  jackfish is offline
Ok, let me try this. Most of your program material is going to come from your fronts, they should dominate. The center channel usually emphasizes voice and other material and while it can sometimes emit up to 50% of the program material it doesn't usually need to equal the size or capability of one of the front channel speakers. The surround speakers are often the closest to the listener and provide only enhancement and directional material.
Each front channel is 8 speakers with:
4 in series/parallel for 4 Ohms
wired in series with
resulting in 8 Ohms
The center channel is 6 speakers with:
4 in parallel for 2 Ohms
wired in parallel with
2 in series for 16 Ohms
resulting in 8 Ohms
Each surround channel is 4 speakers with:
3 in series/parallel for 2.66667 Ohms (2 in series in parallel with one)
1 speaker for 4 Ohms
resulting in 6.66667 Ohms
If you are dead set on a dominant center channel you could go 6 for each front channel, 10 for the center channel and 4 for each surround channel. As such:
Each front channel is 6 speakers with:
resulting in 8 Ohms
The center channel is 10 speakers with:
4 in series for 32 Ohms
resulting in 16 Ohms
2 wired in series for 16 Ohms
resulting in 8 Ohms
Or even 8 for the fronts, 10 for the center, and two (in series for 8 Ohms) for the surrounds. Experiment and see which sounds best.
In some of these arrangements not all speakers will draw the same power, but this shouldn't make a big difference if one uses the receiver to balance or equalize the sound of the system.
Old 08-13-07, 07:51 PM   #8
Alias: Zene
User: #5600
Since: Jan 2007
  Zene is offline
Thanks Jackfish .. I did not mean you specifically in comments, sorry, but do appreciate your more detailed explanation. Glad I don't need huge amounts for the rears. That would eat into the total quantity quickly.
I will build in modules of two so I can experiment.
Would you come over for some many many days and help me build 15 panels? On my large map it's only about 16".
Zene
Old 08-13-07, 08:22 PM   #9
Shack Moderator
Alias: Wayne
Loc: Katy, Texas
User: #8
Just keep in mind that there’s no free lunch. You can wire a lot of speakers together so that the load is ultimately 8-ohms, or whatever your receiver needs, but you’re still driving the amplifier harder to power them all.
Old 08-14-07, 05:24 AM   #10
Alias: Zene
User: #5600
Since: Jan 2007
  Zene is offline
Wayne ... Heard that before, but never understood. If the efficiency is greater for multiples, increased by +3dB per doubling then they should take less power for the same output. 'splain, plz? Could make a big difference on my choices as I only have 50 watts per channel.
Zene
« Home Theater Shack > Manufactured Speakers | DIY Subwoofers > Home Audio Speakers »
Bookmark and Share
Dish Network
