Home Audio Speakers
Advice for TSS - 750
Discuss Advice for TSS - 750 in the Manufactured Speakers and Subwoofers forum; Advice for TSS - 750 I had bought the Infinity TSS 750 and as I read this forum some of you use the same product ...
Views: 642 - Replies: 5
Old 09-03-07, 01:02 AM   #1
the_dragon
Inactive
Alias:
User: #
Posts: n/a
I had bought the Infinity TSS 750 and as I read this forum some of you use the same product with me. I need some help in configure this speakers in order to have the best performance and result of this product, i mean in what configuration it usually make best performances. Thanks for help.
Old 09-04-07, 04:58 PM   #2
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Advice for TSS - 750
the_dragon wrote: View Post
I'm using this speaker systems as a 7.1 (I added a pair of speakers for the back surround)
I'm powering them with a Sony (STR-DE 895) and I also added another sub (Velodyne VRp 1000) ... my room is small (9 x 18 x 8) ... but I'm happy with the sound of the speakers :
I hope this helps ...
Old 10-05-07, 11:53 PM   #3
brendy
Inactive
Alias:
User: #
Posts: n/a
I have the same with an Onkyo 602.By configuration do you mean crossover seting ? Mine is at the 120hz recommended by Infinity.
Old 10-09-07, 01:19 AM   #4
the_dragon
Inactive
Alias:
User: #
Posts: n/a
well, I combine the speakers with H/K AVR 235, the sound is great and clear, but I think I should do some adjustment with each of speakers. I put the crossover for SW same as yours Brendy and it give best sound result. But, anyway, I need some enlightment here, as a newbie , I need to know the best configuration for my speakers (right now i put 1 db for centre and 7 db for surround), so if you don't mind to share your experience for the configuration with me?
Old 10-09-07, 06:14 PM   #5
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
My TSS-750 is paired with Sony STR-DE897 ....... the crossover is set from factory at 120Hz so I can't do anything to change it ...
I used to have the center at 3.5dbs, sorrounds at 7+ and sub 4+ ...
What I recommend you is to get the Radio Shack SPL meter (or any other meter) ... it will help you to get the right configuration when you calibrate all speakers ...
I did it last weekend, I don't recall the final set up .. but, is less than what it was before and the sound is a lot better ... before, my subs (2) were overpowering the rest of speakers ... now they blend better with the rest ...
I will check the final adjustments and I will post it ... but I'm sure it won't help because every room, receiver, set up, etc. is different ...
Old 10-09-07, 06:45 PM   #6
brendy
Inactive
Alias:
User: #
Posts: n/a
Every receiver and room will be different. A Radio Shack SPL meter is what I use.
