Home Audio Speakers
Speaker placement question
Discuss Speaker placement question in the Manufactured Speakers and Subwoofers forum; Speaker placement question I am about to recieve my Klipsch RB - 81 7.1 speakers and have a very challenging room to try ...
Views: 696 - Replies: 6
Old 09-23-07, 02:57 PM   #1
Alias: Instal
Loc: Victoria BC
User: #8076
Since: Apr 2007
  Instal is offline
I am about to recieve my Klipsch RB - 81 7.1 speakers and have a very challenging room to try to fit them in properly. I have virtually no floor space to work with so my only option is to ceiling mount them angled down and in toward the listening area. Has anyone else had to resort to this and if so what were your results? Am I breaking every rule of speaker placement? I currently have my RB - 81 mains mounted this way and it seems to work fine. Ceiling mounting allows me to get proper placement laterally and I thought that was the most important factor. All thoughts are appreciated. Thanks
Old 09-24-07, 12:18 AM   #2
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Re: Speaker placement question
Do you have some pics of your current setup?
I've seen speakers mounted on front walls, but I'm not sure I've ever seen any hangin' from a ceiling. What's on the floor beneath where the speakers are hanging from? Again, pics might help us better understand.
Old 09-24-07, 06:45 AM   #3
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Hey Instal,
I used to have my speakers mounted very close to the ceiling, although they were actually attached to the walls. I had one in each corner for a total of four. At the time I was only using them for music, no movies.
In general, it worked, but I was mostly using it for background music. Unfortunately, a lot of the soundstaging was lost by having them so high up (I guess my ceilings were kind of tall, probably 9+ feet). Imaging was also lost, and I would have had a hard time enjoying them for serious music listening.
I usually find things a little more forgiving when watching movies as compared to music-only listening. You might be able to get away with it and still be happy. But I do believe that for best results, you want to get those speakers around ear level, else it's going to sound like everything's coming from "way up." I'd work to at least get the front three speakers to ear level as much as possible. I would be able to live with the rears mounted higher up than the fronts if necessary.
Good luck!
-- Otto
Old 09-24-07, 08:00 AM   #4
Alias: Steven
thewire's Avatar
Loc: lake ozarks MO
User: #9828
Since: Jun 2007
  thewire is offline
I think it is alright also for the rear channels. My rear speakers are placed about 2 feet higher than the rest and I cannot tell even in the rear row. I had to do so in order to get them firing unobstructed to the front row.
Old 10-06-07, 08:28 PM   #5
Alias: Instal
Loc: Victoria BC
User: #8076
Since: Apr 2007
  Instal is offline
Thanks for the help guys, I found a pair of stands for my surrounds that are 42" high which allows them to clear a couch so I don't have to ceiling mount.
Old 10-07-07, 08:41 AM   #6
Alias: Steven
thewire's Avatar
Loc: lake ozarks MO
User: #9828
Since: Jun 2007
  thewire is offline
sweet! that will improve your quality allot.
Old 10-26-07, 12:58 PM   #7
Alias: Zip
MatrixDweller's Avatar
Loc: Canada
User: #10408
Since: Jul 2007
  MatrixDweller is offline
Ideally you want them to be at the same level as the screen/TV. Above or below will make it sound like the movie is coming out of somewhere other than the screen/TV. The center is best behind the screen for the same reason, you want to dialog to be projected out of the screen. That being impossible with anything other than a perforated screen, slightly below or above, tilted up/down is the next best option. Tweeters should be about or pointed at ear level if possible.
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
