| Home Audio Speakers Breaking in a speakerDiscuss Breaking in a speaker in the Manufactured Speakers and Subwoofers forum; Breaking in a speaker snickelfritz wrote:
A simple way to isolate changes in the speaker would be to wire them out of phase, place ... |
Views: 1820 - Replies: 32
| | #26 | |||||
| Re: Breaking in a speaker Quote:
To prove speaker break in you would need to take an initial full frequency range SPL reading out-of-the-box and then others at given intervals in a controlled environment. | |||||
| | #27 | ||||
| Re: Breaking in a speaker I suspect that it varies with different designs. The stiffness of the spider and surround and their effect on resonance frequency could easily change over time. If so, I would also expect extreme aging to have an effect. I had a pair of early Thiels with a passive radiator and I am sure that they changed with time, mostly on the bottom, as the surround became weaker, as it was the primary determinant of the mechanical stiffness of the passive...no other damping. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #28 | ||||
| Re: Breaking in a speaker In an effort to make my post even more confusing, I have added a lot of stuff to it.... http://www.hometheatershack.com/foru...t-fiction.html | ||||
| | #30 | ||||||
| | #32 | ||||
| Re: Breaking in a speaker I remember that my new speakers were icy cold when I took them out of the trunk of my car. I would not doubt that the cold speakers sounded different. But then 4 hours in the living room should be adequate for "breaking in". Nick | ||||
