| Home Audio Speakers Need inexpensive bookshelf speaker recommendation/opinionsDiscuss Need inexpensive bookshelf speaker recommendation/opinions in the Manufactured Speakers and Subwoofers forum; Need inexpensive bookshelf speaker recommendation/opinions I am looking to get a set of inexpensive really good sounding bookshelf speakers for my living room (only going ... |
Views: 1683 - Replies: 7
| I am looking to get a set of inexpensive really good sounding bookshelf speakers for my living room (only going to be using for 2 channel music. I would like to spend a max of $110. I will be powering them with an old but good JVC receiver and JVC 5 disc CD changer. I listen to all kinds of music with an emphasis on alternative, rock, techno, and some Jazz. I have heard the Insignia speakers that Best Buy carries that have been a big hit with people but would like to audition more before I make my choice. No sub will be used with the system..so bass response to 55HZ or so is important to me. Thanks for the help! | ||||
| | #2 | |||||
| Re: Need inexpensive bookshelf speaker recommendation/opinions Quote:
![]() ![]() ![]() To save you some time (I was looking earlier for some speakers too) I found this fluance speakers http://fluance.com/fldyhidetwbo.html http://www.fluance.com/fldycothhisp.html If you still wants to get it at Best Buy, to me the Sony 8" is a better option ... 3 way and a known company ... just my opinion ... ![]() ![]() | |||||
| | #3 | ||||
| Re: Need inexpensive bookshelf speaker recommendation/opinions | ||||
| | #4 | ||||
| Re: Need inexpensive bookshelf speaker recommendation/opinions Last edited by jackfish; 09-27-07 at 11:47 AM.. | ||||
| | #5 | ||||
| Re: Need inexpensive bookshelf speaker recommendation/opinions "I am looking to get a set of inexpensive really good sounding bookshelf speakers for my living room (only going to be using for 2 channel music. I would like to spend a max of $110." You've already entered the oxymoron...This hobby has VERY VERY little that you could describe that way especially at $110.00.First places to check are your local pawn shop and then www.audiogon.com. If you find what you're seeking new; we're probably ALL interested in that, so could you please quickly forward me the make and model. I'm sorry, I am NOT trying to sound or be condescending, but I just don't know if such a thing is possible or exists when one takes into account purchase of materials, driver manufacture, assembly, shipping, etc etc. no matter how cheap the labor in China/Vietnam/Malaysia/Thailand or wherever. Best for less: the new PSBs at $249.99 pr. Sound great, less filling! I know that you can in fact get speakers for that kind of money it's just the "really good sounding" part that I'm referring to. Good luck. Cheers, Konky. | ||||
| | #6 | ||||
| Re: Need inexpensive bookshelf speaker recommendation/opinions If I were you, scrape up another $50-$60 and drive to AV123 HQ & buy Black Satin X-LS http://www.av123.com/products_produc...s&product=82.1 I forget where in CO they are located.... | ||||
| | #7 | |||||
| | #8 | ||||
| Re: Need inexpensive bookshelf speaker recommendation/opinions I can second the R150 for good sound for the $$$. I run four of them in my living room system. Bass is a little weak, as you'd expect from a small box with a 5.25" woofer, but they don't do anything glaringly bad. I ran them full range for a number of months before partnering them with a pair of NHT1259 DIY subs. On their own, with test tones in a 22x20x9 room plus openings to most of the rest of the house, they were usable into the 50-60 hz range, although I wouldn't call it flat. Not trying to discourage HTS purchases, but they can usually be found for considerably less than the Shack store price, which itself isn't bad. With your budget, I would probably consider the bigger brothers R50 and R300 tower versions, which can be purchased NIB around your price range fairly easily. -Brent | ||||
