Home Audio Speakers
Surround speaker placement?
Discuss Surround speaker placement? in the Manufactured Speakers and Subwoofers forum; Surround speaker placement? I will begin a dedicated HT in Jan. I have the typical room over a garage with a 5' knee ...
Views: 651 - Replies: 5
Old 10-18-07, 07:06 PM   #1
New Member
Alias: Dan
Loc: Willow Spring, NC
User: #5199
Since: Dec 2006
  Dbeistel is offline
I will begin a dedicated HT in Jan. I have the typical room over a garage with a 5' knee wall and a slanted ceiling. (see attached) The room is 14' wide and approx 21' long and the floor to ceiling height is 8'. I'm going to raise the ceiling height to 9'.
My question is where do you guys place your surround speakers, on the knee wall or on the ceiling. My surrounds are Def Tech BP1 bi-poles
Old 10-18-07, 07:27 PM   #2
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Ht Room Over Garage
Dbeistel wrote: View Post
First of all ... Welcome to the forum
Now, about the speakers ... is preferable to have it at ear level (that's what I read everywhere) ... so in your case I think you can use the knee wall, or you can also use the ceiling (I see that is angled down) ... my recommendation is to try both places and see which position give you the best sound
Good Luck
Old 10-18-07, 08:04 PM   #3
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
I did an install several years ago with a similar setup and mounted the surrounds mid-way of the angled upper portion. I used angled speaker brackets so that the speakers were not angled to far towards the floor and it worked out fine. However, as David suggested, you could always test it both ways. For testing the upper portion of wall you may have to get someone to hold the speakers while you listen to the same surround passage a few times.
Old 10-18-07, 09:33 PM   #4
Alias: Funky Waves
User: #9943
Since: Jul 2007
  funky_waves is offline
Here is a picture of an install with our FW4.1's, the wireing is in the cieling with binding posts through the drywall, with big washers on the backside for support. You can mount them anywhere on the cieling and drop them to any hight you want. They can also be angled down with diferent length wires.
Nathan Funk
Funky Waves Audio
Old 10-18-07, 10:04 PM   #5
Owner
  Sonnie is offline
Now there's an idea!
Old 10-19-07, 07:15 AM   #6
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
salvasol wrote: View Post
With surrounds, you actually want them 2-3 above ear level to produce a sound harder to localize, but for mains and centers, yes, ear level.
caveat: unless you are listening to 5.1 music. Some of that is designed to have all speakers at ear level.
