| Home Audio Speakers Anyone using multiple fronts and centers?Discuss Anyone using multiple fronts and centers? in the Manufactured Speakers and Subwoofers forum; Anyone using multiple fronts and centers? I would like to know if anyone is using 2 or more centers, fronts, and backs. Do you like the ... |
Views: 773 - Replies: 31
| Anyone using multiple fronts and centers? I would like to know if anyone is using 2 or more centers, fronts, and backs. Do you like the results? Does it require the need for seperate amp? Or is a quality Stereo enough to get the job done? | ||||
| | #2 | |||||
| Re: Anyone using multiple fronts and centers? Quote:
Kal | |||||
| | #3 | ||||
| Re: Anyone using multiple fronts and centers? Several HT builders at AVS have more than one centre speaker..as I have also..but not duplicate L or R or backs. They have one centre speaker mounted above the screen and one mounted under the screen.. Angling a single centre speaker up or down can sometimes have an adverse effect..particularly with centre speakers that have rear firing drivers and or ports Instead of directing the sound towards the centre line of the screen, the sound becomes more localized, infact not angling the speaker can sometimes work better.. Having a top and bottom centre speaker helps to offset the problem.. I have three centre speakers, one above the screen and two below...The top speaker has two rear firing bass speakers and ports, and the bottom speakers have rear firing ports.. They are wired in series/parallel to maintain impedance matching with the other speakers.. The result of this setup is that I get good strong pinpoint voice location across the entire screen, with no emphasis above or below the horizontal centre line of the screen.. | ||||
| | #4 | |||||||
<<<snip>>> Quote:
![]() Kal | |||||||
| | #5 | ||||
| Re: Anyone using multiple fronts and centers? After reading both posts it looks to me that one set of perfectly placed speakers (as long as room acoustics and space permit such a set up), should be all any in home theater should require. However, if you have a difficult lay out or lack the knowledge or proper testing equipment installing several speakers can correct poorly placed speakers allowing you to obtain the same goal. Is this correct? If so it is a matter of money. You can place speakers right or spend more money on extra speakers and place them in ok positions. I only have the two of you to go by so I guess I will need to pull out some old speakers and try doubling up and see what kind of improvements I get. I may need more speaker wire for the test and was trying to prevent spending any money. Thanks for the advice. I will try both of your suggestions. | ||||
| | #6 | |||||
Vitually, yes...The bottom two are side by side (upright), in the vertical centreline with the top speaker.. I originally tried it with just one at the bottom, but the top big one ( which has 7 speakers in a 3 way crossover system) is an 6 ohm unit and is more efficient than the bottom 2 way 6 ohm speaker..So I parallel wired the two bottom speakers, and series connected the top speaker, giving an approx. total overall of 9 ohms..The Receiver is set to 8 ohms.. This just about perfectly matched the efficiency of all the speakers.. I only claim that this is only practical when using centre speakers that have rear firing speakers and or ports.. If one is using a standard sealed system or a bass reflex system with front ports, then one speaker above or below the screen is all that is needed.. | |||||
| | #7 | |||||
If you are using a sealed enclosure type speaker, or a BR with front ports, then one above or below the screen is all you need.. Other than that, the centre speaker should match tonally and efficiency wise with your left and right speakers.. | |||||
| | #8 | |||||
![]() ![]() I have two pairs of front speakers (2L + 2R) ... I got opinions that I might have problems, but I didn't listen and set up the two pairs ....I did it, not because I was lacking sound, the speakers sounded good to me (but, I need to use REW to know for sure how my system is performing) ... ![]() I did it, because I removed a pair of speakers that I was using as surround, and instead of putting them away I decided to add that pair in the front .. now I'm using them with the speaker selector A + B in my receiver.I gained 5bds using the four speakers instead of two ... but after I use REW, I will decide to keep it or remove it ... ![]() Here is a picture of what I have (you can see that my speakers are small, that help with position) | |||||
| | #9 | ||||
| Re: Anyone using multiple fronts and centers? Do you get a "bigger" sound from the dual left and rights?... This was something that I was going to try, but was advised that it's not the best idea to combine A+B speakers on the receiver.. | ||||
| | #10 | ||||||
Kal | ||||||
| | #11 | ||||
| Re: Anyone using multiple fronts and centers? Quote: Kal | ||||
| | #12 | ||||
| Re: Anyone using multiple fronts and centers? I would stack them vertically in a WTTW configuration and see if there is an improvement, especially in the midrange. I have Large Advents so stacked and the sound is incredible. | ||||
| | #13 | |||||
I gainned 5 bds using them together (I used the SPL to measure the sound with one and the two pairs and that was the difference) ![]() ![]() This is a temporary set up ... I have to use REW to measure the response to decide if I keep it or not. Somethimes we like to experiment things, Right ![]() ![]() | |||||
| | #14 | |||||
| | #15 | ||||||
| Re: Anyone using multiple fronts and centers? Most likely because they will be run in parallel, thereby presenting a difficult load to your receiver/amp. Depending on the receiver/amp, this may or may not present a problem. If it's a problem, it will most likely be present at higher volumes, as that's when the most current will be demanded from the amplifier. All that said, I have done all types of parallel speaker installations and A+B installations (my own stuff, I'm not a pro "installer") over the years and have never had a problem. If you find that your receiver/amp is getting hot, distorting or shutting down, then you have a problem. If not, go for it. Quote:
-- Otto | ||||||
| | #16 | ||||
| Re: Anyone using multiple fronts and centers? I wonder how it would be to stack them on top of each other with the top speaker turned upside down where both tweeters are closer together... ![]() | ||||
| | #17 | ||||
| Re: Anyone using multiple fronts and centers? I tried it. I have 4 surrounds and 2 centers. This is not the best test setup as the 2 centers are not the same brand and are obviously not matched. One center above and one below. One set of speakers are about level with the lower center and the second set is about level with the top center. I am not intrested in numbers just sound for now. I can honestly say it placed the center sound completely dead center of the screen. My wife thinks I am nuts. She sat down to listen I told her to close her eyes. First, I moved the single center to several positions until I found the spot she said is sounded best. Without telling her, I turned on the top center and she instantly began to smile. She said "It sounds better.... so are you trying to get my permission to spend more money" Of course there is a good chance that the center speaker I own may not be right for this room. All I know is it sounds better to me and my wife with more than one speaker. I will experiment more later. I would never have tried this if it wasn't for the fact that I have always been able to point out the center speaker with my eyes closed. At least until now. I honestly can not tell where the sound is coming from. | ||||
| | #18 | |||||
| | #19 | |||||
| | #20 | |||||
I think I was told that it reduces the dampening ability of the receiver.. | |||||
| | #21 | |||||
| | #22 | ||||
| Re: Anyone using multiple fronts and centers? Thinking outside the square can sometimes yeild surprising results.. ![]() | ||||
| | #23 | ||||
| Re: Anyone using multiple fronts and centers? When exhorted to "think outside the box" by a management consultant, our chairman of Psychiatry responded by saying that people who do are usually kept on medication. ![]() Kal | ||||
| | #24 | ||||
| Re: Anyone using multiple fronts and centers? They are wired in parallel. I would have tried A&B but I did not have enough speaker wire for both speakers to reach the system. I will likely try that next. The top speaker was installed upside down so the tweeter is at the lowest point of the speaker, the lower speaker is right side up so the tweeter is at the top. this seams to mend the two speakers into one even though there is a gap of about 2 to 3 feet between them. However, moving the lower speakers to far to the left or to far to the right really screws with the sound quality. But when placed just right the two speakers become invisible and the sound seems to come from out of now where. I mean if you look the speaker the sound does not appear to be coming from it. Maybe a meter would tell a differnt story. But it sure has my ears, my wifes ears, and now my wifes girl friends ears fooled. | ||||
| | #25 | ||||
| Re: Anyone using multiple fronts and centers? I tried this upside down configuration..WTTW..with my two lower centre speakers last night, stacking them on top of each other, and was surprised at the results.. I still had the good centre of screen voice imaging, with a good spread across the screen, but the voices were projected more forward than previously.. Also loud explosions had more impact with a sharper crack as the explosion began.. Definitely an improvement and I'll be keeping them setup this way.. | ||||
