Home Audio Speakers
7.1 Floorstander System - any specific tips/hints for best set-up???
Discuss 7.1 Floorstander System - any specific tips/hints for best set-up??? in the Manufactured Speakers and Subwoofers forum; 7.1 Floorstander System - any specific tips/hints for best set-up??? I was looking for suggestions too. However, in my situation in wall speakers are being used. I did run into ...
Views: 945 - Replies: 30
Old 11-08-07, 11:49 PM   #26
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
  Scuba Diver is offline
Re: 7.1 Floorstander System - any specific tips/hints for best set-up???
I did run into some very intresting speaker layouts on the DOLBY website.
http://www.dtsonline.com/dts-hd/71-f...r-surround.php
Old 11-09-07, 08:58 AM   #27
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
  Kal Rubinson is offline
Scuba Diver wrote: View Post
That's not the Dolby website, is it?
Kal
Old 11-09-07, 10:25 PM   #28
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is offline
Daddy Cool wrote:
I wanted to ask this seperately; having experimented a bit, I find that when my floor-standers ARE set at 'full range' with no LPF crossover, I get a (subjective?) all-round, fuller/beefier, 'sharper' and generally more satisfying soundstage, than when I try various crossovers.
I would measure the subwoofer esponse at your seat to make sure you are getting a relatively flat FR. If you are, it could just be that you prefer the subjectively punchier bass from the mains which could be a result of more second order distortion. If you aren't achieving a flat response from your sub, the peaks and nulls could be muddying up the bass by overemphasizing certain ranges and underemphasizing others.
Old 11-09-07, 10:55 PM   #29
Alias: Brad
User: #12504
Since: Oct 2007
  Tiny is offline
I don't feel so alone now having big floor speakers for my theater. Current arrangement as of today is a pair of 15" 3-ways in the front and another pair in the back with a pair of behemoth solid wood cased 12" models. That could change tomorrow. i am picking up a pair of DJ speakers with dual 18" drivers per 5ft tower. Those might make their way up front, instead of to the garage.
Old 11-10-07, 02:22 AM   #30
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
Kal, Your right it is the DTS site.
Old 11-29-07, 07:38 AM   #31
New Member
Alias: Ravi
User: #13881
Since: Nov 2007
  Spycatcher is offline
Hi Daddy Cool,
Just wanted to check how are your MA Br5's doing sound wise? I am planning to go for a pair and just wanted to check your opinion on them. I will be teaming them up with a Marantz 4001 or 5001 av receiver.
90% of usage will be pure music - classic rock, jazz, blues
Thanks for your help
Ravi
