| Home Audio Speakers Center-Mains MatchingDiscuss Center-Mains Matching in the Manufactured Speakers and Subwoofers forum; Center-Mains Matching I was wondering if people can give me some tips on improving the sonic match between the center channel and ... |
Views: 821 - Replies: 30
| Center-Mains Matching I was wondering if people can give me some tips on improving the sonic match between the center channel and main speakers. I own the B&W LCR600 center and B&W 603S3 mains and drive them with a Yamaha HTR-5960. I can't help but feeling that the match is not always ideal. Vocals on 5.1 mixes sound slightly recessed when they come from the CC. For a while the mismatch was especially glaring when I was using Yamaha's self-equalization. The equalizer made movie CC dialogue much less intelligeable. How perfect do other folks find the match between their center and mains? Do you guys use different x-over settings for each set of speakers? | ||||
| | #2 | ||||
| Re: Center-Mains Matching I use three identical speakers for L/C/R. Even then, room placement/acoustics preclude a perfect match. ![]() The usual culprits causing poor center/voice intelligibility with reasonably matched speakers are poor placement and poor room acoustics. Kal | ||||
| | #3 | ||||
| Re: Center-Mains Matching Kal is right, you might want to play with placement and room treatment. When I installed my center channel speaker (matched with the sides) it sounded very dead with poor dialog. I installed some sound absorbing material behind and above the speaker which made all the difference in the world. It sounded like a different speaker. Hope this helps. Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #4 | |||||
| Re: Center-Mains Matching Quote:
Regards, Wayne | |||||
| | #5 | ||||
| Re: Center-Mains Matching Thanks for the replies guys! I've had the system for a while, but it's only recently that I've started to listen to 5.1 mixes on it. I'm hoping the problem is the setup. The CC sits on a tray inside a wooden entertainment center. The tray slides out ~ 10 inches, but there is no absorbing material behind it. I might give that a try. I'll try to post a picture later. | ||||
| | #6 | |||||
The Yamaha does have a CC equalizer, but it has limited manual control. I haven't tried playing with it myself, other than letting the YPAO tune it automatically. The auto tune sounded like . I'll take a look at the equalizer again, but I don't think I can change the preset equalizer frequencies and Q's. -Mike | |||||
| | #7 | |||||
| | #8 | ||||
| Re: Center-Mains Matching I'll take a REW trace this weekend to get a better sense of the difference between the center channel and the mains. Would you guys recommended running the center as large or small on the receiver? | ||||
| | #9 | |||||
I posted the pics of my home theater here. I can try stuffing some acoustic material behind the center. I also haven't tried plugging the rear port on the center. -Mike | |||||
| | #10 | ||||
| Re: Center-Mains Matching Hi Mike, Looking at the pictures I would have to say that you biggest issue may be caused by the placement of the center speaker as you will get some strange harmonics caused by the entertainment center. Have you tried placing the center channel speaker on top of the Entertainment center and angeling it down slightly just for a test? Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #12 | |||||
Kal | |||||
| | #13 | ||||
| Re: Center-Mains Matching Frequency response (i.e. SPL) isn't the only thing that will affect how well a center matches the mains. Sometimes the SPL is the same, but it still sounds different. At that point, you either need to figure out what's making it sound different (e.g. reflections off an entertainment center) or get new speakers because they will just sound different. | ||||
| | #14 | ||||
| Re: Center-Mains Matching Another thing to look at is your DSP settings on the Yammy... There are several choices of Theater Mode...General, Sci-FI, Adventure etc..and also speaker position in relation to room size...delays mainly.. I have found that if these are not set correctly, then voices particularly can sound withdrawn and indistinct.. | ||||
| | #15 | |||||
Kal | |||||
| | #16 | ||||
| Re: Center-Mains Matching Hello, It is difficult to have a CC sound perfect. I think that CC sounds diffrent from L and R channel because they are not in the corner like the L and R speakers (not the same reflexions). Acoustic panels and some EQ should resolve this. Your HT cabinet should be part of the problem because it causes sound reflexions that could boost some frequency. To put the CC on the top is a good suggestion. Good luck ! Jean-Pierre Imbeau ROTEL RSP-1098|RCD-1072|RDV-1060|RT-1080|RLC-1040|RB-1080x2|RMB-1075|RSP-976 PIONEER ELITE PRO-940HD|BDP-HD1|inno|YAMAHA NS-1000|NS-1000M|CA-1010|CT-1000|TC-1000| YP-1000|PEERLESS XXLS-12x4|HP MediaCenter (Vista Madia Center) + HP MediaSmart Server (Windows Home Server) with 4TB 2.0 TB|BEHRINGER DSP1124P|ECM8000|TOSHIBA HD-A2 My Peerless subs building thread | ||||
| | #17 | |||||
If I use the built in Yamaha equalization, I can't really tell if I'm getting any closer to an equal match. Then again the Yamaha equalizer filters are fixed at 100, 300, 1k,3k,and 10k. | |||||
| | #18 | ||||
| Re: Center-Mains Matching Prof, I usually listen in Straight mode, which I think has the effects turned off. I used to think some of the DSP effects sounded cool, like Vienna Hall, but now I find them distracting. -Mike | ||||
| | #19 | |||||
Kal | |||||
| | #20 | ||||
| Re: Center-Mains Matching This is what makes this hobby fun, finding the best sound from your system. I think if you will keep experimenting with different levels, eq's, speaker placement, sound absorbsion, etc, you will eventually find the right combo. I myself have been extreemly pleased with my setup especially when I added a Denon recv'r that has Audessey incorporated with it. It, so far, has given me the most natural sound I have heard on my system. I did have a Yammie before and like the Adventure mode in my HT room. But, I didn't use it's internal setup to align my speakers. I found it more accurate to use the SPL meter and test tones. Keep at it. Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #21 | |||||
That is very interesting. I just tried listening more carefully to the white noise again and there is difference my L and R speakers, too! The right speaker sounds slightly "lower" than the left. The center channel is "higher" than both. It could be due to my room. The right speaker is very close to a coach. I won't have time to investigate further until the weekend. -Mike | |||||
| | #22 | ||||
| Re: Center-Mains Matching Thanks for the encouragement Dennis! yeah, this is hobby is a lot of fun. Audyssey sounds pretty cool. I got a long HT upgrade path, but eventually I hope to have a receiver with Audyssey built in. | ||||
| | #23 | |||||
Carpet, hardwood flooring, curtains, furniture and even the shape of walls and ceilings make a huge difference. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | |||||
| | #24 | |||||
Kal | |||||
| | #25 | |||||
I use the "General" setting with no additional DSP added for movies..I find this gives the best "theatre" feel for most movies.. The Straight mode is generally recommended for music listening.. | |||||
