| Home Audio Speakers Martin Logan in the house!Discuss Martin Logan in the house! in the Manufactured Speakers and Subwoofers forum; Martin Logan in the house! It's not an issue for me. I'll see if I can get you a response graph posted today.... |
Views: 4631 - Replies: 106
| | #101 | ||||
| Re: Martin Logan in the house! It's not an issue for me. I'll see if I can get you a response graph posted today. | ||||
| | #102 | ||||
| Re: Martin Logan in the house! I'm not so much interested in a response graph, as I'm sure it stays reasonably flat to at least 60hz. I'm worried that a single 8" wouldn't be able to keep up in the 80-250hz range when volume levels get spirited. What is the woofer configuration like on your model of speaker Sonnie? | ||||
| | #103 | ||||
| Re: Martin Logan in the house! Hi Steve! Long time! As far as we are not talking about insane levels, a stereo 8" woofer system can do a good job. My mains have dual 8" each but I am also using dual 18" subs powered by 4 KW (as you know) and I feel they are even in their duties. ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #104 | |||||
| Re: Martin Logan in the house! Quote:
The one thing I really like about these speakers is when I close my eye I can imagine one or a couple of gigantic speakers 10' tall stretching all across the room... one big huge sound stage (I hope I am describing it correctly). ![]() | |||||
| | #105 | ||||
| Re: Martin Logan in the house! Sonnie, the midbass capabilities on your speaker look much more competent than that of the Vistas. Yours is using a 10" woofer that is crossed down at 280hz, so it should be extremely capable in the midbass range. The Vistas use a single 8" woofer crossed at 450hz, not really confidence-inspiring. | ||||
| | #106 | ||||
| Re: Martin Logan in the house! Yeah... I cannot speak for the Vista line. You might check over at the Martin Logan Owners forum. Those guys are usually very helpful and there are a lot of Vista owners. Personally... from what I have researched, the Ascent i's are among the dealer favorites short of the Odysseys, Summits and a couple of the other upper end models. One dealer who knew I had already purchased mine stated that they are his favorite short of the Summits. You may be able to line up a listen with one of the ML owners through the Owners forum. | ||||
| | #107 | |||||
Steve, you are correct in your doubts that a single 8" can keep up with the ML panels. In terms of power curve (ability to maintain he same freq. resp profile at varying SPL levels), most hybrids with a single mid-bass or woofer driver are challenged at levels above 90dB SPL. It took an array of six Adire Extremis 6.8's to really match (and probably exceed if I let it) the SPL power curve of a SL3/Ascent/Vista class panel. See my assessment of this in this thread on a hybrid line array ESL I built as a center channel. However, most ML hybrids do just fine at 'normal' listening levels. As the sheer clarity (pardon the pun) of the ESL more than makes up for a slight deficiency in mid-bass. Also, correct room treatment can improve things dramatically at the mid-bass as well. | |||||
