| Home Audio Speakers How high should back speakers be with DolbyHD?Discuss How high should back speakers be with DolbyHD? in the Manufactured Speakers and Subwoofers forum; How high should back speakers be with DolbyHD? I have read different height requirements from different sources. Is there any difference in set up with the new DolbyHD. ... |
Views: 561 - Replies: 3
| How high should back speakers be with DolbyHD? I have read different height requirements from different sources. Is there any difference in set up with the new DolbyHD. Is approximately 2 feet from the top of your head when in the seated position still the recommended height? Well, I have not heard anything back so I will go with the old setup recommendation and hope it sounds ok. Last edited by Scuba Diver; 11-08-07 at 10:39 PM.. | ||||
| | #2 | ||||
| Re: How high should back speakers be with DolbyHD? You are correct, but feel free to experiment as well. Some people like to put them higher then that because they become obstacles for guests and family. When I get my new surrounds (Axiom QS8), I plan on putting them as high as possible and just slightly pointing them down towards the listeners. TV: Panasonic TH-42PX60 Cable: Motorola w/HDTV DVD: Panasonic DVD-S52 Receiver: Yamaha RX-V2200 Remote: Logitech Harmony 880 Main: Axiom m80 v2 CC: Mission 77c Surround: Bose 701 Sub: SVS PC13-Ultra | ||||
| | #3 | |||||
| Re: How high should back speakers be with DolbyHD? Quote:
Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||||
| | #4 | ||||
| Re: How high should back speakers be with DolbyHD? I am currently working on a design for the FW4.1's in where the surround speakers when hung from the ceiling can be raised and lowered at will, possibly even with a remote control. That way they can be at optimum hight when in use, adjustable for different uses, and also out of the way when not in use. Here is a picture of the Fw4.1 hanging. Nathan Funk Funky Waves Audio | ||||
