When Home Theater Shack owner Sonnie Parker first received his new pair of Montis speakers from MartinLogan, he sent me an email reporting that he had quickly set them up, guessing at the best location and angle for two-channel listening in his home theater, plugged them in, sat down to listen, started up some music, and found them sounding so great he about cried. He listened to them for hours on end almost without touching that initial setup over the next few weeks until I arrived to evaluate the Montis and the accompanying MartinLogan StageX center channel speaker for this review.
When I first heard the MartinLogan Montis, I instantly understood what he meant. Everything about their presentation was just downright impressive. That was the first of two times that I would get chills over the next few days while working with Montis and StageX speakers.
Having had a chance to read through the review already, I was astounded by the amount of effort Wayne and Sonnie put into doing this review - great job!
I am guessing you provided the muscle while Wayne listened to see if you needed to adjust more - that is worth something (or I do even less at our evaluations than I thought! )
Sonnie, all I can say is congradulations. I know how pleased you were with you last set up, I can only imagine how satisfied you must feel now. My guess is you are home now, I'm happy for you knowing how much you enjoy this!
I haven't read through the entire review yet, but I did notice something that might need your attention... when you click on the StageX picture at the top all you get is an error message. The link for the pic is broken.
Nice review , at some point i would like to ear myself this speakers but they are hard to find locally and to have a serious listening and at the Montreal show never ML was present officially .
I have not heard this model but do have some experience with Martin Logan and can say y'all have hit the nail on the head. The stunning reproduction of lower mid's on through the highest frequencies is hard to beat, soft and delicate when called upon and yet raw and loud the next. Soundstage for days that is hard to duplicate yet exceed.
Yes, the surround version of Wish You Were Here on the blu ray ( immersion) is only beat by attending a live performance. Stunning !
Fantastic review gentlemen! :T I enjoyed it all, and it has suddenly and unexpectedly piqued my interest in electrostats, which previously have not been something I have seriously considered. I very much look forward to Wayne's review of the EM-ESL speaker to see how much of the Montis goodness has been packed into it. That is a speaker I could afford (barely) and consider owning. Although it will be in a different room with different equipment, I hope to see some comparisons of the Montis and the EM-ESL to get a feel for how close I could get to the Montis.
One part of the setup that would be difficult for me would be the distance from the front wall. I could set speakers up at 6 - 7 feet away from the front wall for 2-channel listening, but that position would put them nearly 4' ahead of the screen. How would things sound for movies and multi-channel music videos if the front of the speakers were 2.5 - 4 feet away from the wall behind them?
OK, a little leak on the ESL review... Still writing, but - performance is very close to the Montis, although not as deep in the bass (ported vs. sealed with DSP) and maybe not as well suited for a big room like Sonnie's. In my smaller rooms, and about 3 feet out from the wall - Dynamite! Lots more to say about them, but that is the quick summary. (Oh, and some more detail on getting an absolutely killer soundstage.)
Oh, also I'm curious about the Wish You Were Here blu ray disc. I found one on Amazon, but it appears to be a documentary. I was under the impression it was a live concert. Which one would I be looking for? Thanks.
Thanks for this very informative review/set-up tutorial! I've already significantly improved my sound using the set-up information. The sweet spot information is really quite valuable, and adjusting the rake with that information as a guide made a very worthwhile difference to my ears. I do have several questions I'd like to throw out, and any help would be appreciated:
1. Is the speaker plane to ear plane measurement correct? Only 69"? Is that typical?
2. What does Listening Angle (in this case, 21.5 deg off axis) refer to? This term confuses me.
3. Is it best to absorb as much of the rear reflections as possible if you're limited by external contraints to 40" from speaker plane to the front wall? I just haven't been able to draw a clear conclusion via listening because the answer seems to vary depending on what's being played - or depending on something else I'm not aware of.....
Probably not typical the way most people would set them up, but then neither was the result we got. That setup gave us a very deep soundstage. We tried locations closer to the front wall, also with excellent results, but Sonnie preferred this one.
Zero degrees Listening Angle means the speaker is pointed straight at the listener. If it is turned away from the listener, usually outward - for instance the left speaker pointing toward the chair to the left of the listener, from his seated perspective - then the angle of that turn is the Listening Angle.
Zero degrees Toe-In means the speaker points straight at the back wall.
I say no, but the answer is actually a bit complicated. There will be quite a bit of detail in the MartinLogan ESL review I am finishing right now. Hopefully it will be helpful.
Thanks very much for your reply. After "just following" your recommendations (from the review and from your 2-ch setup guide) instead of "finding excuses not to", I have a pretty stunning soundstage, and without any real compromises. Well..., the speakers do "seem like" they're in my lap, but who cares? I'll get used to that. To anyone else reading this who is "not so sure" - consider just trying what the AudiocRaver suggests. Looking forward to the rear reflections information in your ESL review. Regards, Thom
Basic question - can these play Rock and Hard Rock well.
I've always liked the sound of 'Stats, yet I've never really had the time to pop in some AC/DC, Metallica, Stevie Ray Vaughn, Van Halen... and let it rip.
I've heard electrostats aren't great for this, but there are a couple reviews that say these do much better for hard rock.
Key for MartinLogan is the hybrid design with a cone driver handling low frequencies so the max excursions of the panel remain very small. We rocked out quite a bit with the Montis and they never complained. We have heard other all-panel speakers "fuzz out" on heavier bass notes, but never the MatrinLogans. That is one of the main qualities I like so much about them.
I have a question. Just booked a Montis and Stage-X to replace my Paradigm Studio 100. For HT playing , would you set the Front L/R cross over frequency in AV Receiver to 40hz or more. I have a paradigm Sub 15 which goes low up to 34hz. For stereo playback, i use stereo integrated amp and the speakers will run at full range as expected.
Now that's what I'd call stirring the pot! Looking forward to seeing how the new players hold up!
I wonder if ML ever considered smaller electrostatic panels for Dolby Atmos application. Small, maybe like 24' X 8." Could mount them close to the ceiling & that curved panel would probably be great with dispersion. They would weigh practically nothing!
I hope there will be a thread opened up about this GTG if it happens Would love to hear how the A5 stacks upto the mighty ML and all the other speakers y'all have heard in the CCC since the original A5. Seriously considering the upcoming L7 when it hits
I wouldn't expect the A5 to keep up with the ML. That is just a different class of speaker. I originally intended to get the L7 set, but they were taking longer to develop. I had the money during the A5rxc's group buy & I new they sounded great, so I went for them. And they are sweet.
The A7 however should be able to hold its own. Jon says he expects if to be "really something special that he has always wanted to put his name on." I think he wants it to be his statement piece. As good as Jon is at building/designing speakers...I'm really looking forward to them as well.
It's funny how everybody in that 1st eval has wound up with a pair of them! Truly great speakers for the dollars that Jon charges.
Yes of course it would be unreasonable to think that the $10k pair of speakers wouldn't be a better performer than the <$1k pair. Plus they're very different technologies. Still, comparisons are always interesting. I'm really looking forward to seeing how the L7 turns out though.
Been waiting a long time for the L7, and may end up buying a pair before a review. Jon has been silent on the timeline for a while now, so I have no idea how much longer it will be, but I'm not ready yet anyway. Regardless, very much looking forward to reading what you think about it, Wayne.
Related Threads
742.3K posts
170.9K members
Since 2006
