Home Audio Speakers
Bookshelves on "L" brackets off wall ??
Discuss Bookshelves on "L" brackets off wall ?? in the Manufactured Speakers and Subwoofers forum; Bookshelves on "L" brackets off wall ?? I am about to bring home some bookshelf speakers and wanted to know if I will lose any AQ by ...
Views: 1536 - Replies: 4
Old 11-16-07, 11:47 AM   #1
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
  E-A-G-L-E-S is offline
I am about to bring home some bookshelf speakers and wanted to know if I will lose any AQ by placing them on wooden DIY "L" brackets off my PJ screen wall?
I don't want to use stnads as the reason I am getting bookshelves is to open up the space my towers take up and to give a sleek look with black bookshelves against my black velvet wall.
Old 11-16-07, 01:28 PM   #2
Alias: alexadams77
User: #10654
Since: Aug 2007
  alexadams77 is offline
Re: Bookshelves on "L" brackets off wall ??
What type/name bookshelf speakers are you referring to? As long as none of the speakers' components (speakers, ports, etc) are blocked by the bracket, there should be no problem. Also ensure that there is adequate space around the speaker as well.
TV: Panasonic TH-42PX60
Cable: Motorola w/HDTV
DVD: Panasonic DVD-S52
Receiver: Yamaha RX-V2200
Remote: Logitech Harmony 880
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
Old 11-16-07, 09:06 PM   #3
Alias: Brent
brent_s's Avatar
Loc: Wilmington, NC
User: #7037
  brent_s is offline
It depends on what type of placement the speaker was optimized for.
Most quality speakers, bookshelf and tower, are designed with some Baffle Step Correction in the crossover to account for the the perceived loss of output as the wavelength produced gets larger than the speaker's baffle. There's a theoretical 6db of SPL difference at frequencies shorter [higher] than this point and longer [lower] than this point. In real world rooms, the correction needed is usually more like 3db.
Anyway...if you take a speaker with BSC and place it directly against a wall as you've described, you "increased" the size of the speaker baffle, which lowers or eliminates the baffle step. It's likely to sound bloated or bass heavy compared to a more typical placement 12"-18" away from a boundary.
Old 11-16-07, 10:58 PM   #4
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
They are PSB Image B25's. They are 'front' ported, so I was hoping the sound characteristics wouldn't be affected?
Old 11-19-07, 09:07 PM   #5
Alias: Brent
brent_s's Avatar
Loc: Wilmington, NC
User: #7037
  brent_s is offline
From reading the manual and Stereophile review of the B25s, it appears PSB intended for them to be used in fairly close proximity to a wall or sitting on bookshelf. Before putting holes in the wall, I would try to simulate their final placement to determine if such placement will induce any undesired bass emphasis.
-Brent
