Home Audio Speakers
Review: Klipsch Cornwall III vs. Cornwall I
Discuss Review: Klipsch Cornwall III vs. Cornwall I in the Manufactured Speakers and Subwoofers forum; Review: Klipsch Cornwall III vs. Cornwall I We did not have a lot of time to compare the speakers. They were set up side-by-side at the Klipsch ...
Views: 15338 - Replies: 33
Old 06-19-06, 09:48 PM   #1
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
We did not have a lot of time to compare the speakers. They were set up side-by-side at the Klipsch factory in Hope, Arkansas. Swapped back and forth between them. The Cornwall I vocals seemed a little 'tinny' and not as clear as the III's. Bass on the III was a little stronger.
The CW I had good caps in the crossover, the Klipsch engineers had run a bunch of tests on it, and concluded the crossover was working correctly.
The CW III is on the left, CW I on the right. The woofer on the III is higher than the I. This is to smooth out the bass response.
Notice the III is taller than the I. No sonic advantage...small stand makes it easier to use the vacuum cleaner.
Ron Carlton
Dallas, Texas
Old 06-27-06, 01:25 PM   #2
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
Re: Review: Klipsch Cornwall III vs. Cornwall I
The attached image is a SPL vs Freq. graph of the Cornwall I in Klipsch's anechoic chamber. The purple and red lines are essentially the same line. I believe we tried a new inductor. It did not make a significant difference. The thing to note is the drop off at 400-600 Hz. The green line is swapping the polarity for the squawker (I think). All it did was move the drop to 700-900 Hz.
The drop off is due to resonances set up in the box. Later Cornwall I's used a B-2 crossover that helped some with the dip at 400-600 HZ. Klipsch fixed this on the CW III by raising the woofer (see the above picture).
Ron Carlton
Dallas, Texas
Old 06-27-06, 01:29 PM   #3
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
This photo is from the Klipsch forum. Trey Cannon from Klipsch is working on the speaker. The owner, Seadog standing by in the anechoic chamber.
What other company would do that for their customers?
Ron Carlton
Dallas, Texas
Old 09-16-06, 10:30 AM   #4
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
Liked the Cornwall I's so much I bought 1984 oiled walnut pair. Were 6/10 now 8/10 after light sanding and 5 coats of Tung Oil.
Ron Carlton
Dallas, Texas
Old 09-16-06, 01:02 PM   #5
Owner
Loc: L.A. (Lower Bama)
Very interesting... first time I've seen a test (anechoic I assume) room like the one above.
Old 09-17-06, 12:45 PM   #6
Alias: edd
User: #2120
Since: Aug 2006
  eddthompson is offline
its a pitty we dont realy see klipsch here in the uk, i guess the only thing similar to those would be tannoys, at many times the price i bet as well.
now if only i could emigrate to the us
edd
Old 09-18-06, 12:01 AM   #7
Alias: Bob
khellandros66's Avatar
Loc: Pittsburgh, PA
User: #962
Since: Jun 2006
  khellandros66 is offline
Who's the goof that trusted a Klipsch nut like rcarlton in the building. I mean sheesh I am suprised he didn't run out with pair on his shoulders..
Just messing with yeah dood..I like theri newer THX Ultra 2 series alot. My dad had a pair of old Magnavox speakers (circa 1973-74) The he finally had to let go of when we started on the HT. Those were some great speakers. Horn loaded tweeter and 15in woofers. I remeber the first time I listend to Deep Purple's smoke on the water from LP on them. Really set me on home audio.
~Bob
Old 09-18-06, 06:30 PM   #8
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
Here are some more pictures of the chamber. The revolving door. The entrance to the chamber.
Ron Carlton
Dallas, Texas
Old 09-18-06, 06:33 PM   #9
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
Jubilee...the last speaker PWK helped create.
Ron Carlton
Dallas, Texas
Old 09-18-06, 06:34 PM   #10
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
Closeup of the tiles.
Ron Carlton
Dallas, Texas
Old 09-18-06, 06:35 PM   #11
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
The anechoic chamber.
Ron Carlton
Dallas, Texas
Old 09-18-06, 06:41 PM   #12
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
khellandros66 wrote: View Post
snip
~Bob
I didn't run out with any speakers. Another couple did...Cornwall III's as a door prize:raped: !
Ron Carlton
Dallas, Texas
Old 09-18-06, 06:47 PM   #13
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
Go to this site CWIII to see step-by-step how Klipsch makes the Cornwall III's.
Ron Carlton
Dallas, Texas
Old 09-21-06, 06:10 PM   #14
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
After living with the Cornwall's for a month, used only for two channel through a vintage McIntosh MAC-1700. All I can say is Wow!!!:holycow: Not as big a sound as K-horns, perhaps a more intimate sound. Terrific separation of instruments, nice wide sound stage. Accurate reproduction of the music. Non-fatiguing. Works well with Jazz. Rock doesn't sound too bad either. Haven't played much Classic or Blues yet. No Hip Hop, Rap, at all (no plans to either).
Ron Carlton
Dallas, Texas
Old 10-31-06, 01:06 PM   #15
Coytee
Inactive
Alias:
User: #
Posts: n/a
Say Ron...
That pic of the Jubilee in the chamber sure looks familar!!
(and yes, I just now found this site)
Old 10-31-06, 08:03 PM   #16
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
Just trying to drum up interest and at the same time enter a contest held here earlier for some SVS speakers.
Ron Carlton
Dallas, Texas
Old 11-01-06, 11:54 PM   #17
Seadog
Inactive
Alias:
User: #
Posts: n/a
rcarlton wrote: View Post
....and here are those Cornwalls back at home handling front R and L duty in my all Klipsch Heritage HT.
Old 11-02-06, 08:03 PM   #18
Alias: Bob
Loc: Pittsburgh, PA
User: #962
Since: Jun 2006
:raped:
Aside from the Triad Platinum LCR Center that is the biggest center I have ever seen.
~Bob
Old 11-04-06, 09:17 AM   #19
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
I'm impressed he could lift it that high. They weigh more than 90 pounds!!!!:holycow:
Ron Carlton
Dallas, Texas
Old 01-21-08, 02:47 AM   #20
davis419b
Inactive
Alias:
User: #
Posts: n/a
Hi.... New member here! Where here in Dallas,Tx can I go to listen to some BIG KLIPSCH speakers.
Thanks in advance for your replys, Don
Old 01-21-08, 08:52 AM   #21
Coytee
Inactive
Alias:
User: #
Posts: n/a
How big do you want to go?
You want to go to the 'top' and hear the Jubilee or do you prefer the more traditional Khorn, LaScala, Cornwall and the like?
Old 01-21-08, 10:14 AM   #22
Coytee
Inactive
Alias:
User: #
Posts: n/a
eddthompson wrote: View Post
Here's Ralph's website http://www.artisanaudio.co.uk/ He's in/near London and could probably get you hooked up with a pair of Jubilees if you wanted (at a price that might surprise you?)
If I recall... his Jubilees are located in his home which is the same place he does the auditions for you. (I don't pretend to speak for him though)
Old 01-21-08, 10:47 AM   #23
davis419b
Inactive
Alias:
User: #
Posts: n/a
I have only gotten back into music now for about six weeks. I started with a set of Klipsch KSP 300, then went to four Bose 901 Series VI. Sounds really great but as you can see I am still looking. I missed out on a set of Cornwalls by one day when I first started looking. I have a set of Klipsch Belle's spotted that I want to hear but they are a four hour drive. I really dont mind that but I would rather look at some local. I looked at a set of Klipschorns but condition was a 5 on a scale of 10.
Thanks, Don
Old 01-21-08, 06:33 PM   #24
Music Moderator
Alias: Ron
rcarlton's Avatar
Loc: Dallas, Texas
User: #262
  rcarlton is offline
The DFW_hornheads have listening parties about every quarter. Last one we heard Cornwall's. There will soon be Jubilee's in Waco. Perhaps that will be where the next meet will be.
Me, I have all the big Klipsch at home: K-horns, LaScala's, Cornwall's and Heresy's.
Ron Carlton
Dallas, Texas
Old 01-21-08, 07:15 PM   #25
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
  yourgrandma is offline
What do you think about the KLF-30's? I know hey arent really clssic Klipsch's, but they were some of the Baddest speakers I'v heard.
I'd love a pair or two of Heresies. A friend has some and let me loose with my iPod and I didn't leave his house till 4:30 AM.
Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
