Home Audio Speakers
Bi-Amping my front speakers?
Discuss Bi-Amping my front speakers? in the Manufactured Speakers and Subwoofers forum; Bi-Amping my front speakers? Hi Guys, Now that i have my Onkyo TX SR805 I have the option of bi-amping my mains. What real ...
Views: 3989 - Replies: 8
Old 12-07-07, 05:33 PM   #1
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Hi Guys, Now that i have my Onkyo TX SR805 I have the option of bi-amping my mains. What real advantage will I really see by dong this as I have never done this before I don't know if its worth the trouble?
I am currently using my Samson servo 4 channel amp to power the mains bridged so its 240watts per channel.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 12-07-07, 05:42 PM   #2
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
  Kal Rubinson is offline
Re: Bi-Amping my front speakers?
I do not believe you will percieve any advantage. OTOH, you can try it free and/or read all the threads which already discuss this.
Kal
Old 12-07-07, 06:01 PM   #3
Alias: mike
mike c's Avatar
User: #147
  mike c is offline
i've bi-amped my full tower speakers (BETA 50) with a multichannel Rotel RMB1077 (100wpc) ... and I heard absolutely no difference.
i much preferred the larger amp instead of the bi-amped setup.
Old 12-07-07, 07:58 PM   #4
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
mike c wrote: View Post
I have also biamped with the same large amps and, imho, there is no difference once the mono amp is sufficient to the task.
Kal
Old 12-07-07, 08:47 PM   #5
Alias: mike
mike c's Avatar
User: #147
  mike c is offline
Kal Rubinson wrote: View Post
Kal
yeah, I started with the receivers (85wpc and 120wpc) powering the towers ... then moved to a bridged 180wpc Rotel RMB1066 ... i got an improvement there (2.0), but after I bought the 1077 ... there was no more "upgrade" in SQ.
it was also during my use of the 3 channel amp that I discovered that it is still the front two channels eating the most wattage ... the center (even though the vocals and dialogue all come out there) did not require as much wattage.
i am now using bridged behringer a500's for the front soundstage. (360wpc) i don't need it, but it's fun to not be worried about clipping.
Old 12-08-07, 02:25 PM   #6
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Thanks everyone for your responses. I will just leave well enough alone for now.
Home theater:
Two Channel system:
My Webpage
Old 12-09-07, 01:58 AM   #7
drf
Alias: drf
drf's Avatar
Loc: Somewhere else.
User: #3282
Since: Oct 2006
  drf is offline
What features does this reciever have that makes it suitable for bi-amping? with basic pre-outs you will still need an active X-over and speakers designed for bi-amping to make it worthwhile.
Bi-amping can yeild significant benifits if you have setup up your X-over properly. Some people just run 2amps from their pre's and dont use crossovers which will yeild vitrually no difference. Others go to the trouble of using standalone active x-overs which give superior control over each driver and its subsequent output.
"Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless
The imperative is to make a subjective study an objective fact.
Old 12-09-07, 01:06 PM   #8
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
The Onkyo has crossovers built in that are adjustable but I would have to use the receivers built in amps to achieve this (130watts) is plenty. I really wanted to help off load the receivers amps by using my outboard Samson servo amp.
So I think I may just leave it the way I have it (powering my Mission 765's) as it still sounds fantastic.
Home theater:
Two Channel system:
My Webpage
Old 12-16-07, 06:38 PM   #9
Alias: warpdrive
warpdrive's Avatar
User: #8762
Since: May 2007
  warpdrive is offline
I went ahead and tried biamping my speakers because I have an Onkyo 875 which has the same capability. I did not notice one bit of difference at all except more clutter behind my video cabinet
