In Wall Thoughts... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Audio Speakers
In Wall Thoughts...
Discuss In Wall Thoughts... in the Manufactured Speakers and Subwoofers forum; In Wall Thoughts... Could anyone give me some input or background on either system here..... Bass will be handled by an SVS PB12-Plus... ...
Old 12-08-07, 01:19 PM   #1 (Link)
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
Warpdrv is offline
In Wall Thoughts...
Bass will be handled by an SVS PB12-Plus... I was thinking about this for a bedroom system.
Both are closed back systems
Niles
for the front 3 IW2650LCR , and the IW650FX for the side surrounds..
FR is 70Hz To 20kHz +/-3dB
Or
Atlantic Tech.
IWCB-626 all the way around... FR 54Hz – 20kHz ±3dB
http://www.atlantictechnology.com/default.asp?NodeId=67
I'm leaning towards the Atlantic Tech's based on FR and crossover abilities...
But maybe someone else has some thoughts on this...
2 way(AT) system vs 3 way(Niles)
Old 12-09-07, 02:21 PM   #2 (Link)
Loc: Lower Alabama
Re: In Wall Thoughts...
This is one thing I don't read much about... in-wall speakers. Not sure why, but despite there being a host of advertising for them, I don't see much discussion about them.
Sonnie
Old 12-10-07, 02:39 PM   #3 (Link)
Alias: alexadams77
User: #10654
Since: Aug 2007
alexadams77 is offline
You may want to double check the "Niles" link, as you have the product name instead of the website as your hyper link.
I looked into getting the in wall speakers for quite sometime and read a lot of reviews. I was looking to use them as my rear surround speakers, but in the end decided against them. There's not too many people around that I could find that actually had them. Instead, I had to read reviews online and make my own judgment from there.
A couple of questions:
What type of budget are you working with?
What are your expectations from the speakers?
How big is your room?
Speaker limitations (size, wall penetration/excursion, etc.)?
I only looked at a handful of in-wall speakers and found that the Axiom "W" series were very easy and straight-forward to install.
You may have to do what I did and make your judgment based off of reviews on the internet.
TV: Panasonic TH-42PX60
Cable: Motorola w/HDTV
DVD: Panasonic DVD-S52
Receiver: Yamaha RX-V2200
Remote: Logitech Harmony 880
Main: Axiom m80 v2
CC: Mission 77c
Surround: Bose 701
Sub: SVS PC13-Ultra
Old 12-10-07, 04:27 PM   #4 (Link)
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
Warpdrv is offline
Hey Alex... & Sonnie, thanks... fixed that link...
First off... I know that Inwalls aren't the most popular, and are a compromise but I was shooting for as good a quality as I can...
My budget is about $3K... and these are for my bedroom about 1700^3, and Im looking for something in the descent SQ to watch movies and listen to music in bed, and have tunes on that side of the house kind of scenario...
My walls are 2x4 depth...
I know what the retail prices of those speakers are, but my buddy is shooting me a good deal.. but I can't really audition them, the guy is 2 hours away... and I don't even think he has them setup...
Just hoping to find someone that had heard either of the speakers in question here.
I had also looked at Triad, but they are more money then I wanted to spend here.
Old 12-10-07, 06:22 PM   #5 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
We sell the Niles and I found that for less money I could get about the same sound with the MTX speakers. I really liked the B&Ws but didn't want to spend the $$.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 01-05-08, 04:08 PM   #6 (Link)
New Member
Alias: Jon
Loc: Illinois
User: #15066
Since: Jan 2008
HT Crazy is offline
I went with Niles because they are known for in-wall speakers and I wanted a speaker enclosure with in the wall. I have seven Niles Audio HD6 in-walls with the Niles speaker boxes in the stud cavity and they sound incredible. For the subs I went with two Velodyne DPS-10's. I think this is one great sounding room.
Old 01-07-08, 08:19 AM   #7 (Link)
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
Warpdrv is offline
Forgot about this thread... I ended up not doing in-walls... I pre-ordered the SVS Mts-01's so I will see how they end up...
Thanks for your thoughts and help, but the more I researched it, I would have to spend way more money on inwalls to get the enclosed back, and sound quality I was looking for... I'm really hoping the MTS's are worth the wait...
Similar Threads
RL-p18 Sonotube thoughts... bnw SoundSplinter 50 11-30-07 04:00 PM
Thoughts on swivel tweeters. nova Home Audio Speakers 4 10-15-07 04:34 PM
Any thoughts on this 15? good for IB? lvisneau DIY Subwoofers - Infinite Baffle 9 09-19-07 09:16 AM
New System What are your thoughts? Dougie085 Home Audio Speakers 5 11-08-06 02:46 PM
New Sub: Monolith Response, any thoughts? 3ll3d00d REW Forum 6 10-23-06 09:11 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
