| Home Audio Speakers What crossover frequency????Discuss What crossover frequency???? in the Manufactured Speakers and Subwoofers forum; What crossover frequency???? I have a small dilema about the crossover frequency for my HT ...
After I did the auto calibration of ... |
Views: 3278 - Replies: 19
| I have a small dilema about the crossover frequency for my HT ... ![]() After I did the auto calibration of my system, the receiver set the crossover at 160Hz, I know I can manually adjust it to the recommended 80Hz ... but I don't know What's best??? ![]() My speakers have different frequency response, maximum is 20KHz and minimums are 35Hz, 65Hz, 80Hz, 120Hz and 130Hz (I have a pair of each, not just one ) ... and here is where I have the dilema of what's best??? ... If I leave the crossover at 160Hz, I'm okay, all the speakers can handle anything above that ... but What if I set the crossover at 80Hz??? ... What will happen with the speakers with the 120Hz - 130Hz response??? ... the receiver will send all signals above 80Hz, but if speaker can not handle anything between 80Hz and 130Hz, What will happen with that signal??? ... Will I miss something there??? ... is there a lot of sound on that range???Do you think is better to set the crossover at 130Hz??? ... all speakers can handle that ![]() ![]() ... I want to get the best sound possible, and just in case ... upgrades are schedules for the future (to replace the speakers with 120Hz - 130 HZ response ) | ||||
| | #2 | ||||
| Re: What crossover frequency???? Are you still running the Sony STR-DE897 receiver? Does it allow for separate crossover points for each speaker? If not... I would be more concerned with localization of the subwoofer with the response extending to 130Hz or 160Hz. The Auto-Setup set your crossover to 160Hz because that is what is thinks your speakers can handle or it could not recognize the response from your speakers below 160Hz meaning you could have a null in that area with your speakers. | ||||
| | #3 | ||||
| Re: What crossover frequency???? Do a simple REW measurement to check how low your speakers can go. I would setup the crossover frequency to whatever gives you the best curve with mains and sub(s) around your sweetspot. Now, as Sonnie pointed out, using a different crossover frequency for each type of speakers is probably the best way to go. Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha | ||||
| | #4 | ||||
| Re: What crossover frequency???? Also, it might not be the capability of your speakers; it might just be their location. If your speakers happen to be sitting in a spot where certain low frequiencies are landing in a valley(lull), then simply moving the speakers to a better location might help. Sometimes just moving them a few inches can do it. Take multiple measurements and always confirm with a SPL meter. | ||||
| | #5 | ||||
| Re: What crossover frequency???? NT Last edited by MrPorterhouse; 01-07-08 at 08:36 AM.. Reason: Multiple post. | ||||
| | #6 | |||||||
| Re: What crossover frequency???? Quote:
![]() Quote:
![]() Quote:
.... I also noticed when doing the auto-calibration, that the receiver didn't give the same results after each calibration ... I remember seeing different distance, levels, EQ ... ![]() | |||||||
| | #7 | ||||
| Re: What crossover frequency???? I have a little Onkyo which only sets to one freq. I was told 80hz and setting all speakers to SMALL would be a good idea way to go. As for the sub................. auh...... ![]() | ||||
| | #8 | ||||
| Re: What crossover frequency???? Can somebody clarify this for me ... ![]() ![]() I'm making some changes ... now, all my speakers are able to handle 65Hz to 20Khz (except my center 120Hz - 20Khz ); I set my crossover to 80Hz, but what will happen with the center speaker??? ... it will be receiving signals that can't process ... Will this damage the speaker??? ... Will I miss something in that range (80Hz-120Hz)??? ... I will get a new speaker for the center, hopefully soon ...I know that I can set the crossover at 120Hz, but I'm trying to avoid the sub localization ![]() | ||||
| | #9 | |||||
I'm an equal opportunity fanboy. I love and currently own stuff from B&W, Paradigm, Dynaudio, Sony, SVS, Denon, Velodyne, Mirage, AKG, Headroom (all subject to change at any moment) | |||||
| | #11 | ||||
| Re: What crossover frequency???? It does ... I have this options for the crossover: 40, 60, 80, 100, 120, 140, 160, 180 and 200 ![]() I was saying 80Hz because that's the most recommended, and 120Hz because is the lowest frequency reponse for my speaker ![]() ![]() | ||||
| | #12 | ||||
| Re: What crossover frequency???? ![]() ![]() ... you see what happens with this addiction ![]() ... this is what I ordered http://www.jbl.com/home/products/pro...at=CCS&ser=VEN ... is the best match for my fronts ![]() ![]() ![]() | ||||
| | #13 | ||||
| Re: What crossover frequency???? Since you have a new center......problem solved, a 80Hz crossover will work fine for all your speakers. I'm an equal opportunity fanboy. I love and currently own stuff from B&W, Paradigm, Dynaudio, Sony, SVS, Denon, Velodyne, Mirage, AKG, Headroom (all subject to change at any moment) | ||||
| | #14 | |||||
![]() ![]() .... (What's next??? ![]() ![]() ... separate amps??? ... HD DVD??? ...BR??? ... Will see )![]() ![]() | |||||
| | #15 | ||||
| Re: What crossover frequency???? You know the answer: All of the above I'm an equal opportunity fanboy. I love and currently own stuff from B&W, Paradigm, Dynaudio, Sony, SVS, Denon, Velodyne, Mirage, AKG, Headroom (all subject to change at any moment) | ||||
| | #16 | ||||
| Re: What crossover frequency???? | ||||
| | #17 | ||||
| Re: What crossover frequency???? Finally ... I got my new center speaker ![]() Now my audio set up is JBL's in the front (Stadium (L + R) and Voice (C)) and Polk M10 for my surrounds (4) ... ![]() ![]() ![]() I did the auto calibration with the YPAO ... and to my surprisse the crossover frequency was set at 60HZ ... Should I set it back to 80Hz or leave it at 60Hz??? ... the only speaker that can't go down to 60Hz is the center (70Hz - 20KHz per manual) ![]() | ||||
| | #18 | ||||
| Re: What crossover frequency???? I'm not sure. Normally I'd think an 80hz crossover for the sub would be best, but it does look like your stadiums go pretty low. Hmm.. I guess I'd try it both ways and see which one sounds best. If I had to guess without listening, I'd probably leave them as is. Sometimes those autocalibration things also eq a little (at least I think they do), which may be messed up if you change the crossover setting. Also, I wouldn't worry too much about the center channel going down to only 70hz.. it's used mostly for dialogue which won't go that low anyway. Anyway, that's my $0.02. JCD | ||||
| | #19 | |||||
![]() You're right about the EQ at the calibration, I can see the curve for every speaker, but I haven't change anything there ... I guess I need to try both ways like you said (60Hz and 80Hz); and also I need to check what sound best sending the Subwoofer output to just the Sub or Sub + Fronts (I have that option in my receiver setup) ... the Stadium can go to 35Hz (same as the Sub ) but I read that is better to let the Sub handle the lower frequencies, so the speaker can perform better with the higher frequencies , I know that I may need a better Sub, but that's for the future ... I think that I'm not missing anything below 35Hz, because I have my buttkickers to handle anything the Sub can't ![]() ) | |||||
| | #20 | ||||||
![]() My mains go down to 35Hz and I get a much better experience when my SVS PC-Ultra gets in and all the other speakers are set as small. Really, you have to experience what real deep bass is. Could be addictive, so be careful ! ![]() Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha | ||||||
