| Home Audio Speakers I think I`m missing out hereDiscuss I think I`m missing out here in the Manufactured Speakers and Subwoofers forum; I think I`m missing out here I am using Polk Audio surroundbar,according to specs the lower range is
-3dB limit 100Hz ; upper range -3dB limit ... |
Views: 478 - Replies: 6
| I am using Polk Audio surroundbar,according to specs the lower range is -3dB limit 100Hz ; upper range -3dB limit 20Khz. Does this mean I am hearing nothing below 100Hz? When my subwoofer arrives should I set the crossover to 100 or higher as opposed to 80? I read that about 95% of movie soundtrack is above 30Hz,how much is below 100Hz? I think I`m missing out on a lot using only the surroundbar. Hear is link to lab test if it will help http://www.hometheatermag.com/compac...lk/index2.html | ||||
| | #2 | ||||
| Re: I think I`m missing out here It drops off like a cliff below 100Hz... yes, you are missing a lot. I would probably try 100Hz on the sub. You'll want to get REW setup so you can measure the response of your sub to see if you will need to smooth it out. | ||||
| | #3 | ||||
| Re: I think I`m missing out here I have the same dilemma in my set up ![]() ... but in your case you're lucky because you only have the soundbar, so I think you're safe setting the crossover at 100Hz, even at 90Hz or 80Hz you won't notice a big difference. My case is different, my speakers have different frequency response (35Hz, 65Hz, 80Hz, 120Hz and 130Hz) ...my receiver is set at 80HZ but I'm not sure if I'm missing something (maybe not, because the speakers with 120Hz and 130Hz are surrounds ... but who knows ) | ||||
| | #4 | ||||
| Re: I think I`m missing out here yes, set the crossover to 100Hz when you get your sub. I'm an equal opportunity fanboy. I love and currently own stuff from B&W, Paradigm, Dynaudio, Sony, SVS, Denon, Velodyne, Mirage, AKG, Headroom (all subject to change at any moment) | ||||
| | #6 | ||||
| Re: I think I`m missing out here Yep, it probably is. Another thing is that as you set the crossover higher, especially about 80Hz, the placement of the sub will become somewhat limiting due to the fact that you'll be able to hear where your sub is with sound information above 80Hz. Normally, you don't want to hear the location of the sub, so you'll probably want to place your sub in the front of the room to help mask it. | ||||
| | #7 | ||||
| Re: I think I`m missing out here Personally...my 2 cents worth: I'd set it at 120hz initially, with placement of it (the sub) up front. If that creates too much localization; then try 100hz, but you'll probably have a gap that will be noticeable at 100hz. Let us know how it goes...good luck! Cheers, Konky. I get up...I get the paper...I read the obituaries...if I don't see my name; I go ahead and have breakfast! George Burns. | ||||
