Home Audio SpeakersDiscuss Bi-amp or... in the Manufactured Speakers | DIY Subwoofers forum; Bi-amp or... I have a question!, I just dont know, is it better to use an amp with more power to power ... |
Views: 1346 - Replies: 22
| Bi-amp or... I have a question!, I just dont know, is it better to use an amp with more power to power my speakers or Bi-amp the speakers , I have VR3 boston Acoustics and a Emotiva LPA-1(125 watts x 6)I can run the LPA-1 6 channel, 125 + 125 on each speaker Bi-amp If more power is better I will upgrade to the new 5 channel Emotiva (200 watts x 5) Thanks!! ![]() | ||||
| | #2 | ||||
| Re: Bi-amp or... Hi personally would say bi-amp, 125w per speaker driver is enough power really unless you have a really big room. Bi- amping with give a smoother and better defined sound. See how you like the sound bi-amped and then upgrade, if you can up the power to 200w per driver all the better. | ||||
| | #3 | ||||
| Re: Bi-amp or... I'm going to bi-amp my Ascent i's when I get my NAD T785. It has 7 channels... I plan to reassign those 2 extra channels to the front. | ||||
| | #4 | ||||
| Re: Bi-amp or... I would go with bi-amping assuming the ams have great sound, and they do. Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, High fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Onkyo TX-SR707 7.2 Receiver w/AudysseyXT Panasonic DMP-BD605 Blu-Ray player Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #5 | |||||
| Re: Bi-amp or... Quote:
| | #6 | ||||
| Re: Bi-amp or... So is it better to just let those two extra channels do nothing? (This is not a sarcastic question. ) | ||||
| | #7 | |||||
. So I would recommend you do what you want, but tell the OP to save his money and keep the amp he has. | |||||
| | #8 | ||||
| Re: Bi-amp or... Kinda off topic...sorry...Sonnie, what happened to the Anthem equipment you were getting? Just curious. Cheers, Konky. I get up...I get the paper...I read the obituaries...if I don't see my name; I go ahead and have breakfast! George Burns. | ||||
| | #9 | |||||
Kal | |||||
| | #10 | ||||
| Re: Bi-amp or... Hi i would agree keep the amp for the time being and upgrade when the op is ready, but would also say 200-250watt is fine. I think each of my drivers sees around 200-225watt for the mid bass and sub-bass into 4 ohms via a tri-amp setup and would say they could still do with around 50-100w more, buts thats my preference. The extra power adds better dynamics, image ,handling of the speakers, extra real loudness and so on. I once ran some 50watt pioneer mid speakers with a 300w p.a. power amp and they loved it. Also maybe the op could then use a decent active cross-over as it adds so much, definitely one of the best upgrades for me so far was going active. Last edited by stephenb1; 01-22-08 at 07:46 PM.. | ||||
